  • Guests: 24
My single switch with feedback - 70cm sparks!
Mates
Mon Nov 02 2009, 08:39AM Print
Hi guys,
I started experimenting with feedback using my single switch and the Red Traffic Cone beast and first attempts are not bad. Sparks are 70cm long (no interrupter!). Unfortunately my feedback had very strange behavior and I will need some help to figure it out. I’m using Steve's mini sstc design Link2 with following modifications: There is no external oscillator (like 555timer) and the system is powered from a 12V battery. The funny thing is that my body is a necessary part of the feedback system (more on the video). I have to touch the antenna to start oscilations and keep the system working. Moreover my body needs to be in certain position, I have to be sitting at certain distance from the coil (not very practical). However, the results are quite impressive so now I need to solve the problem how to avoid my body to be part of the system. Any suggestions?
Video: It is not the full power; I used only 150V at maximum! Link2
And few pictures wink
1257150867 1025 FT0 Sg105166
Plying with higher voltages was deadly for one of my IGBT. This spark-over killed it .The spark hit the driver not the primary! I will have to cover the secondary with few layers of epoxy to avoid this in the future.
1257150867 1025 FT0 Graphic1
Mon Nov 02 2009, 09:26AM
Hello Lad,
I am very interested in single-shot technology (krytrons etc)
I will help you out to the extent of 50 - 100E6 aluminium
450V inverter-type electrolytics.
What would you do with a crate of these?
luv,
Stella Maru XXX
Mon Nov 02 2009, 04:07PM
Quite impressive Mates!
Use the 555 pulser. It will push the setup in oscillation.
Keep the good work!
mmt
Mon Nov 02 2009, 05:51PM
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
wow, awesome result, so this coil is running on CW? i had almost similar problem with this antena, try to use a 1N4148 diodes instead of 1N60 or dircet antena to the top, or make it longer, or try it aim to the secondary.
Lethal Shot
Mon Nov 02 2009, 06:52PM
Lethal Shot Registered Member #1623 Joined: Tue Aug 05 2008, 03:31PM
Very cool result Mates.
Have you tried to add a capacitor from your antenna to ground?
Your body is basically a capacitor and probably grounded one way or the other,
only i have no clue what ratings, also there are very few datasheets for this type of cap. tongue
Mon Nov 02 2009, 08:26PM
That's very nice, never thought you could get such output from the single-ended topology...
Mates
Sat Nov 07 2009, 11:33AM
Hi coilers,
New update…
I finished current transformer feedback and tried the full power for the first time. The coil works pretty well. I plan to prepare complete schematics of this concept including the power part and the driver. I'll post it soon.
Cheers Mates
Video: Link2
1257593528 1025 FT78824 Small
Note the side spark amazed
Sat Nov 07 2009, 01:01PM
Wow very impressive for a single switch coil. Might be worth to scale it up with some large single switch bricks :)
Sun Nov 08 2009, 10:31AM
Cool, it's nice to see some new designs being tried. Especially ones yielding such good results!
brtaman
Sun Nov 08 2009, 12:32PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Indeed, very good results! Must say I am in love with the conical secondary, it really sets the whole coil apart from the pack.
I would also like to state that I applaud your continuing efforts with the single switch topology you have been working around with for quite a while. It is really paying off! Congrats on a great coil.
