  • Guests: 55
FBT - help
yoni
Mon Oct 26 2009, 09:05AM Print
yoni Registered Member #2366 Joined: Tue Sept 15 2009, 10:35AM
i took a FBT from an old screen and now i want to understand how it works
where in the input volt of it? there are so many wires and inputs there.
i was looking a data sheet and did not find any.
i added some pictures also.
thank you.
yoni
Mon Oct 26 2009, 09:07AM
pictures..
yoni
Mon Oct 26 2009, 09:10AM
from some reason i cant upload the pictures.. i will try again
1256548232 2366 FT78458 Fbt 1
1256548232 2366 FT78458 Fbt2
1256548232 2366 FT78458 Fbt 3
Antonio
Mon Oct 26 2009, 11:53AM
See if you can find the code in the listings here:
Look at the schematics and you will see what are all those pins. The pins in the arc are usually the primary coil and a few other coils, for feedback and low-voltage outputs. One of them is the ground connection of the HV coil. The other pins are the ground connections of the potentiometers and of a filter capacitor.
yoni
Mon Oct 26 2009, 07:07PM
on my model is written: 6174z-1018F 2AG 11
i didnt find it but i found: Link2
which is the most similar but no data sheet..
do you might have another site?
thank you
Antonio
Mon Oct 26 2009, 10:49PM
This flyback is used in the LG CB-795 plus monitor. Here you can find the schematics of this monitor. The flyback connections appear on the last image:
yoni
Mon Oct 26 2009, 11:41PM
It's written on my board T701 and on the shcematic is written T703, is there a difference?
1256600473 2366 FT78458 Untitled
Antonio
Tue Oct 27 2009, 01:21AM
Maybe a different version, or an error in the schematic (very common). You can verify if the connections are as in the schematic. Don't trow away the board. There are lots of useful components on it.
Tue Oct 27 2009, 01:00PM
The board is also a (possibly good) way to drive the FBT, if you can figure out the circuit. Looks like you possibly can power the board "as it is" and get HV (b.t.w. it DO dislike sparks so best for eletrostatic motors, small lifters, and drive HV & CRT tubes)
The circuit as you have it on the board drive the FBT from 190V for the primary and 15V for the FET-driver.
If you use other drive-methods, you can quite easily messure the output voltage on that FBT by connecting pin 11 and 12 and messuring current toward pin 7 (HV return), beware of pin 15, it should be isolated properly if you don't want filter on the HV or connected to pin 7.
What state is the board in? all parts still on it?
Antonio
Tue Oct 27 2009, 03:29PM
Note that in the schematic there is a switching regulator between the 190 V supply and the input for the flyback driver, so the actual input at pin 3 is smaller. There is a complete switching power supply powering the entire circuit, that (if not damaged) can be separated from the board quite easily and used for many purposes.
A better schematic:
