  • Guests: 33
mains ground filter
loveHV
Sun Oct 25 2009, 09:12AM Print
loveHV Registered Member #1854 Joined: Wed Dec 10 2008, 06:09PM
im finished building my second SSTC. But i face a practical problem now, ground.
i made it in my room so i can't run it outside and make a RF ground. i only have mains ground.
but putting an secondary ground to a mains ground isn't a good idea.
is there anyway i could filter mains ground so it doesn't interfere with the computers that are standing here and the TV downstairs ?
Mates
Sun Oct 25 2009, 10:30AM
Hi,
this topic has been discussed already million times on this forum so please try to search for it.
Mains ground always worked for me and I have never experienced any problems. I know bunch of people using mains ground too with the same result...
Cheers,
Mates
loveHV
Sun Oct 25 2009, 10:33AM
ok thanks, wink
Zum Beispiel
Sun Oct 25 2009, 11:35AM
Can you run the ground wire through a window? That's what I did, anyway.
loveHV
Sun Oct 25 2009, 01:08PM
no i have a large roof so i can't.
but i tried mains ground now with 60V over the half bridge had some small 2cm sparks, for the moment it doesn't interfere with anything even my laptop who is connected to the same outlet as the SSTC doesn't act weird .
hope it stays that way with full rectified mains wink
Coherent
Sun Oct 25 2009, 02:47PM
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
If you're really in doubt just unplug anything sensitive like TV's and computers that share the line.
loveHV
Sun Oct 25 2009, 07:04PM
i tested it on half wave rectified mains and the TV got interference so my parents said, my spark length was only 4 cm
so what should i do now ? I don't wan't to bust my tv, and if i unplug it i need to reconfigure the settings (old CRT TV).
also i noticed if i put my desk light in the outlet of my SSTC it lights. and there isn't any ground on that plug, just L & N
Sun Oct 25 2009, 07:39PM
Maybe putting two "Y2" grade capacitors (a few nF) one between earth and neutral and the other between earth and live, would help.
But if something, this will fix just the "down the line" interference problem, not electromagnetic interference through air.
loveHV
Sun Oct 25 2009, 07:53PM
that way of placing caps isn't that done in EMI filters, because ive placed an EMI filter on the lines, don't know if the caps are Y2 grade though. well i will try it see if it works smile
