  • Guests: 47
Help with access to an academic paper
Sat Oct 24 2009, 09:48PM Print
Hi folks, could someone with free university access very kindly download this paper for me, please? Thank you, Harry. smile
Laser and Particle Beams (2007), 25:2:305-312 Cambridge University Press
Copyright © 2007 Cambridge University Press
doi:10.1017/S0263034607000183
A Tesla pulse transformer for spiral water pulse forming line charging
J.-L. Liu a1a2c1 , T.-W. Zhan a2 , J. Zhang a2 , Z.-X. Liu a2 , J.-H. Feng a2 , T. Shu a2 , J.-D. Zhang a2 and X.-X. Wang a1
a1 Department of Electrical Engineering, Tsinghua University, Beijing, China
a2 College of Photoelectical Engineering and Science, National University of Defense Technology, Changsha, China
Abstract
A high voltage pulse Tesla transformer with a coupling coefficient of 0.75 was designed and experimentally investigated. The transformer was employed to charge a spiral water pulse forming line (PFL) in a high current electron beam accelerator, and was featured by its compactness, stability, and reliability. When the primary input voltage is 55 kV, the transformer can charge the PFL to 720 kV with an energy conversion efficiency of 36%. The formulas for calculating the primary and secondary inductances of the transformer were deduced, with which the main parameters of the transformer were calculated theoretically. The distributions for electrical and magnetic fields in the transformer were obtained by the simulations of calculation. In addition, the process of an accelerator of the transformer charging a spiral PFL was simulated through the Pspice software to get the waveform of charging voltage, the diode voltage, and diode current of accelerator. The theoretical and simulated results agree with the experimental results.
(Received November 4 2006)
(Accepted January 31 2007)
Leinad
Sun Oct 25 2009, 05:39AM
Leinad Registered Member #1930 Joined: Wed Jan 14 2009, 07:36PM
Here is that paper.
-EDIT-
Is what I would like to say but, it seems that I am not allowed to upload the .pdf
I do have access to it and have it saved, did I maybe upload it to the forums wrong?
-Dan
Sun Oct 25 2009, 06:14AM
Leinad wrote ...
Here is that paper.
-EDIT-
-Dan
That's extremely thoughtful of you, Dan. smile
If I send you my direct email address in a PM, perhaps you would very kindly send it to me directly?
Leinad
Sun Oct 25 2009, 06:20AM
Yeah sure that would be fine.
Going to try once more here though.
-EDIT
Nope no good. I'll just send it through your direct mail.
-Dan
