  • Guests: 88
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
2" diameter high-density polyethylene rod available - three colors
Herr Zapp
Sat Oct 24 2009, 04:47PM Print
I've got some "excess" 2" diameter high-density polyethylene rod stock available in three colors: black, dark blue, and lime green.
This material has excellent high-voltage insulating properties, and machines very nicely. It's perfect for electrical applications like feed-through or stand-off insulators, coil forms, transformer bobbins, etc., or mechanical parts like spacers, low-friction bushings and bearings, thrust washers, etc. It is usable up to about 248 deg F, with a melting point of ~266F.
Price is $6/foot, plus shipping. The least expensive packaging is probably to just wrap the section of rod in two layers of corrugated cardboard, add a layer of wide cellophane tape, and slap a label on.
Regards,
Herr Zapp
1256402838 480 FT0 2 Inch Hdpe Rod
