  • Guests: 35
01/13 si2030 (62)
One of the best high FPS movies Ive seen
Fri Oct 23 2009, 08:14AM Print
I came across this very high FPS movie of bullets, its a collection of clips from a German manufacturer of high speed equipment.
StevenCaton
Fri Oct 23 2009, 04:58PM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Those are some great clips mads.
c4r0
Fri Oct 23 2009, 06:13PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
I found this gif a few days ago
1256321589 151 FT78255 Bullet
Renesis
Fri Oct 23 2009, 06:59PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
One million fps, i didnt even know that was possible. Amazing.
aonomus
Fri Oct 23 2009, 08:05PM
The bandwidth required for such a camera must be incredible. FPGAs and quite interesting hardware, thats for sure.
The downside is that you need extremely intense light, to the point where photographing living things is hazardous for them. You also need a constant light source (so AC lights flicker, so DC fluorescent or similar lights?).
I know nik has one of those consumer level high speed cameras with some cool shots from it. I hope more hardware like that becomes accessible for the amateur scientist.
Fri Oct 23 2009, 08:12PM
Very nice; thanks for pointing it out.
Along those lines, I'd always liked this video Link2 where camera follows a gun-fired penetrator (not a rocket!) in flight. Not sure what is actively discarded at 0:14.
Clearly the video capture involved a tracking mirror, like the galvanometers used by some of our laserists. At the limit of mirror deflection, we lose track of the flying projectile but can see the tracker "ring" for a few cycles.
Today I found a commercial product for just that application: Link2
It's an accessory offered by a maker of million-FPS cameras. Enjoy!
-Rich
And for the less militaristic, the insects of Ultraslo. When this ladybug Link2 spreads its wings, it needs to let them firm up for a while before starting the engine.
Sat Oct 24 2009, 04:09AM
I have found AC lighting and light intensity to be a problem even with my 300, 600, 12000fps camera. I was thinking about feeding my 500w halogen lamp with filtered DC but over the summer I was shooting outside only where flicker isn't a problem.
Hon1nbo
Sat Oct 24 2009, 11:41PM
Nik wrote ...
you have a consumer level that does 12000?, or is that a typo - the casios, which are the only consumer levels I know of, one of which I have, can only do up to 1200
as for lighting, I use Studio Hot Lights made for cinematography and the like, no problems
florescent will not work because they flicker, and AC lights (normal Tungsten filaments) do not flicker as much as you would think because the Filament does not cool down enough to be very noticable, but it still is to a degree but enough consistency to work with
Stadium lights at sports events are absolutely HORRIFIC I must say, I've been having to deal with them while trying to get footage for my School Teams!
what also could work are strobes for their particular case, because the duration of the flash is much longer than that of the actual event and the source is constant throughout the course of the flash, but my guess is that they used an enormous number of Hot Lights
rp181
Sun Oct 25 2009, 01:27AM
For the very high speeds, lasers are used a lot.
