  • Guests: 60
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Red Traffic Cone - new SSTC with conical secondary - full power
Mates
Wed Oct 14 2009, 09:02AM Print
Red Traffic Cone is a name of a great album made by German band Kraftwerk in 1971 (recommended!) and now it is also a name of my new coil.
I always wanted to experiment with different shapes of the secondaries. It was Tesla by himself who claimed that conical secondary was a breakthrough which shifted his HV experiments up to 100 megavolts range. Here is my first attempt, first test, first sparks at low power and already first big surprise which is related to the wave forms generated by the TC (see the pictures below)
Basic data:
Secondary:
50cm high traffic cone made of PVC
Wire: 0.315mm
Diameter of the base 20cm
Diameter of the top 7cm
Coated by clear acrylic
Primary:
8 turns power cable 16mm (used for high power car amplifiers)
Driver:
Single switch with cap limiter, no interrupter
Driving freq: 185 KHz
Any comments are appreciated, mainly an explanation for the odd wave forms (how the hell is this possible, my previous SSTC with same driver generated only very nice sinus)
1255510560 1025 FT0 Winding
Winding was a PITA work. Much more difficult than winding a classical tube
1255510560 1025 FT0 Assambly
1255510560 1025 FT0 First Sparks 100v
First sparks at low power (30%). Not bad to my standards. I could not get higher becuase an arcing into the primary started wink
1255510560 1025 FT0 Gate Pulses
Gate pulses: PW: 1us, Freq: 5,4 us
1255510560 1025 FT0 Wave Forms
1255510560 1025 FT0 Wave Forms2
This are the waves produced by the coil. Have anyone of you ever seen something like this?
Wed Oct 14 2009, 09:44AM
Excellent! :D
The weird display is caused by the magnetic field from the coil deflecting the electron beam in your scope directly. Try moving the scope further away!
brtaman
Wed Oct 14 2009, 10:26AM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Great conical secondary, how was it to wind?
Hope you don't mind me asking, but where did you get the topload? I have been on a hunt to find a decent topload in Europe, with no luck.
Which IGBT are you using, it seems to be doing the job very well. shades
Mates
Wed Oct 14 2009, 11:32AM
brtaman wrote ...
Hi,
Winding the conical shape was horrible. After three unsuccessful attempts I found that the best way how to do it is to secure each finished section by glue tape and/or nail polish to avoid spontaneous unwinding caused by decreasing diameter. Funny thing was that after I successfully finished the coil for the first time a found a crossed wire in the first third of the coil cry . So I had to unwind it and do it again… But the very last try was a question of 2hours (I had already a lot of experience wink )
The top load was originally a thermal stainless coffee mug which I bought in Denmark. It is double layered so the capacitance is higher than it looks.
Regarding the IGBT, it is BUP314 and for the whole driver design you can have a look here: Link2
Cheers Mates
Wed Oct 14 2009, 12:15PM
Really good to see something a bit new, Mates! Well done!
Wed Oct 14 2009, 12:27PM
brtaman wrote ...
Hi Rok,
search for "stainless steel mirror balls" or "Garden ornament mirror balls" or "gazing balls."
Here's one example, but there are plenty of others, sometimes a bit cheaper:
Wed Oct 14 2009, 04:43PM
Nice idea.
Wouldn't it be easier to start winding from the narrow end?
Mates
Wed Oct 14 2009, 07:59PM
Dr. Kilovolt wrote ...
No, but it is true I tried it as the first option. Problem is that the wire has tendency to slide down.
What is more interesting to me at the moment is to try to place the topload on the other side of the coil (in other words to stand it upside down - on the tip).
Wed Oct 14 2009, 08:11PM
Mates wrote ...
Super cool that you did this! I have tried once to make a conical secondary too, but gave it up as it was a pain to do and at the moment I thought noone had done it, until I found out Tesla did it :)
That could be interesting to see, that you have the high voltage at the end with lowest Fres, if we talk about a secondary that way.
Coronafix
Thu Oct 15 2009, 05:00AM
Haha!! That's great Mates!! I have often thought about doing the same with a traffic cone but the pain I would have to go through to wind it always put me off. Good on you for persisting!!
