  • Guests: 32
epoxy over polyurethane?
lightlinked
Wed Oct 14 2009, 06:10AM Print
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
is it okay to apply a coat of finish epoxy over a polyurethane finish? the polyurethane has been disappointing.
Wed Oct 14 2009, 08:23AM
It is quite usual in yacht maintenance to apply polyurethane over epoxy - the polyurethane having a superior UV resistance. There can be no reason the layers could not be reversed on your coil, so long as the polyurethane is completely cured.
As with all adhesive operations, careful surface preparation is the key to success.
Herr Zapp
Wed Oct 14 2009, 04:11PM
ll -
Can you clarify what you mean by "the polyurethane has been disappointing"?
If the polyurethane you have already applied has adhesion problems, or is "lumpy", or has debris embedded in it, you may not have good results if you try to "cover" the defects with epoxy.
Regards,
Herr Zapp
lightlinked
Thu Oct 15 2009, 12:31AM
it was actually fine untill someone knocked it over while it was outside. it received several nicks but as i wet sanded it there was peeling of the layers. i could give it another shot with polyurethane. actually i might prefer that over spending $25 to buy epoxy.
