  • Guests: 38
Powering a TC with a voltage multiplier
Crunchy Frog
Mon Oct 12 2009, 02:46AM Print
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
Is it a good idea?
For example, using 2 MOTs with single stage CWs (2 diode, 2 cap), one in positive polarity and the other in negative.
Or, doing this with the multiplier already in the microwave (1 diode, 1 cap) so the waveforms are ac with respect to ground and dc with respect to each other. (Does this even work at all? I'm not sure...)
Mon Oct 12 2009, 09:52AM
Worked for me Link2
Crunchy Frog
Mon Oct 12 2009, 05:50PM
Link2 That guy did it with only 2 caps and 4 diodes, but 2 reactors. What's the difference between his circuit and yours?
brtaman
Mon Oct 12 2009, 07:21PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Crunchy Frog wrote ...
He used 35 1n4007's and 16 substantial caps. Scroll down wink
Crunchy Frog
Mon Oct 12 2009, 07:56PM
brtaman wrote ...
I didn't mean physically, I meant in the schematic.
Mon Oct 12 2009, 08:40PM
There is not really much of a difference, if im not mistaken. The link's is only a doubler, with two de-Qing diodes. I made Conner's schematic, and it worked great. Like him i used low capacitance, and high breakrate, up to 3000BPS and could still get 2 foot sparks. I highly suggest it.
Jeep in mind, you can always use series lytics for the doubler. Make sure you have a juicy reactor, if it is not big enough the current can rise faster, and your lytics will get hot. That is not good! Also, the reactor will see around 2 times the voltage of the supply. I used 4 MOTs in series, and they all officially died.
brtaman
Mon Oct 12 2009, 10:17PM
Whoops. Sorry about that, Crazy Frog. angry
Good luck with the project, I would go with McConners version myself, it comes with the guarantee of being engineered by a mastermind.
Tue Oct 13 2009, 05:35PM
Almost all electronics / power supplies / appliacnes, that have a selector switch between 115 and 230VAC utilize a switched-in voltage doubler. Just keep in mind, large stacks of multipliers aren't very efficient and also have a inherit current limiting characteristic.
