  • Guests: 48
Mini Brute Half Bridge driving DRSSTCII Resonator 230v wireing woes.
Doug86
Tue Oct 06 2009, 09:35AM Print
Doug86 Registered Member #2424 Joined: Tue Oct 06 2009, 08:02AM
Hi All,
First post here. I've come down to help James (Audio:Deviant) with his coil construction. Although my knowledge of electronics is slightly stronger than James' I've come into a struggle with conflicting information.
James has used the machanical design from a DRSSTCII, including the Primary (MMC) Capacitor bank, with the low voltage electronics from the mini brute extensively discussed in the sticky.
Somewhere along the line, James was advised not to bother with a full bridge as the DRSSTCII design specifies and that the half bridge configuration is sufficient. below is how he currently has it connected up.
Jamescoilbefore
This rings allarm bells with me and would like the experts opinion smile In particular, whether the return from the primary should be connected to the DC-.
Many thanks in advance.
Doug
Apologies if this should be in the mini brute sticky, I thought that as this coil is a bit of a hybrid that it might take the sticky off topic. Feel free to merge, Thanks.
1254821513 2424 FT0 Jamescoilbefore
Tue Oct 06 2009, 10:11AM
Yes, it's quite normal to connect the primary return to the DC bus negative like that. (Where else could you connect it?)
BTW, the forum has a 400 pixel width limit
Doug86
Tue Oct 06 2009, 10:38AM
Thankyou, resized (although hard to read) :)
