  • Guests: 43
new junky NST
HVPaul
Tue Oct 06 2009, 02:26AM Print
HVPaul Registered Member #2321 Joined: Fri Aug 28 2009, 05:13PM
Hey fellas,
I just picked up this NST from a junk shop.
It's rated at 6kV 30ma. I'd like to use it for an SGTC.
How can I test it safely and make sure it works at all? Don't want to burn it out on the first light.
Label
Open
Tue Oct 06 2009, 03:31AM
Unfortunately, that is a switch mode NST. It will not work for a typical sgtc.
The only way to use it for a sgtc is to rectify the output with ultrafast diodes, and make a DC Tesla coil. I have always wanted a little smps NST to make a small coil with, in fact.
It will be harder to use still, though. Reason being that you *must* have protection for the diodes. Something like a Terry filter would most likely work.
HVPaul
Tue Oct 06 2009, 05:52AM
How would a Terry filter look like for a NST that only has two HV out leads?
