  • Guests: 35
Pole Transformer
1 2 3 4  last
Neil
Sat Oct 03 2009, 04:21PM Print
Neil Registered Member #1458 Joined: Wed Apr 30 2008, 09:47AM
Ive finally been lucky enough to come across a power pole transformer!! cheesey
Its rated 10 kVA at 22 kV with input at 250/500 V. Its also been reconditioned and all freshly repainted. I plan to have it set up as 500 volt input but only run from 240, im hoping this will help with limiting current draw internally and leaving less external current limiting to worry about. This will leave me with about 11 kV output which is the voltage I am after to run a Tesla coil. Aiming to run it at about 5000 Watts through a variac so I can slowly power it up.
I am looking at using 942C20P15K-F capacitors, currently have 192 on their way from the USA. I've got about 10kg of 18 AWG wire here, just need to find a suitable pipe around the 12 to 14 inch mark for me to wind about 1200 turns onto.
I will progressively work on this over the next 6-12 months as I get time, will post more pics when it's finished.
1254585535 1458 FT0 Transformer 1
1254585535 1458 FT0 Transformer 2
1254585535 1458 FT0 Transformer Rating Plate
Sat Oct 03 2009, 04:43PM
Amazing, great find!
These things have really low impedance, I think you'll need almost the same amount of external current limiting no matter how you connect it up...
Killa-X
Sat Oct 03 2009, 05:06PM
Agreed, We have something near that size at our schools electrical class that just sits on a powerpole on the wall for show...It doesn't have those 2 huge insulators though! But it's still a huge rectangular transformer with 2 small insulators.
I agree though, That's a nice fine! Hope it does wonders for you :D
Sat Oct 03 2009, 05:36PM
Nice. What do you plan to use for a ballast?
Sat Oct 03 2009, 07:18PM
Yea, and external ballast is absolutely necessary. It is indeed a great looking transformer! And a nice high voltage ;),
You could just use a spool of wire for ballast. Or you could make your own inductor, or perhaps even use some microwave oven transformers with shorted secondaries for a quick ballast. A home-wound inductor would probably be the way to go for a permanent solution.
rp181
Sat Oct 03 2009, 08:39PM
You seem to be going all out, so i would suggest what richard did:
The one he had made is exactly what you need.
Neil
Sun Oct 04 2009, 01:27AM
Thanks for the comments. Yeah I love those large insulators, makes the thing look half scary! That is a good link you posted RP181, made for some good reading, thanks. I'm leaning toward an inductive ballast for current limiting so I dont throw all my power away as heat using any kind of resistor. Will keep an eye out on ebay or look to make my own in the next few months, might even price up a professionaly made one.
Sun Oct 04 2009, 07:56PM
Dr. Kilovolt wrote ...
Yep, it says right on the rating plate, "Impedance 4.3%". That means the unballasted short-circuit current would be about 25 times the rated current.
rp181
Sun Oct 04 2009, 08:15PM
May I ask how much this cost you, and how much you are planning for the whole project?
Sun Oct 04 2009, 10:23PM
You lucky dog, Neil. I hardly ever hear of anyone getting kit like that in the UK. So please do tell us if you had to get a second mortgage, or if it was one of those miracle things like me getting two glorious Parmeko Neptune transformers today on ebay for less than a tenner for the two because no else bid for them? So do tell... smile
1 2 3 4  last
