  • Guests: 54
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
A few computer power supplies for sale or trade. Also 2 slimline drives.
Sat Oct 03 2009, 12:53AM Print
We got a couple new computers, and we gave my brother one of the old ones, and he bought a bigger 620 watt power supply for it, so i am stuck with some PSU's.
I have a supply that is almost brand new, only been used once. It is a slim long one, and the max power output is 210 watts. Five volt rail is 15 amps, 3.3 volt rail is 10 amps, 5vFP is 2 amps, 12 volt is 12 amps, and -12v is .5 amps. It was bought brand new from Dell, and used once. It uses a single squirrel cage fan for cooling.
I have a pretty old but working 170 watt power supply. This is like the normal ATX supply you would find in one of the larger desktops. 5v is 22 amps, 12v is 14 amps, 5vSB is 2 amps, -12 is 1 amp, and 3.3 is 18 amps. Uses a 50mm fan for cooling, maybe 60mm.
I have a 160 watt supply, that is about a year old, but ever since we got it after a few hours it would shut down for no reason. Sometimes it could stay on for 8 hours, sometimes 2-3. It would be suitable for a bench power supply that does not need to stay on for a long time, though. It is 5v and 11 amps, 3.3v at 9 amps, 12 volts at 11 amps, -12v at .5 amps, and 5vFP at 2 amps. Uses a single ~2 inch muffin fan for cooling.
I do also have a fairly new 'slimline' DVD rom, with an IDE output (with some sort of connector at the drive and a ribbon cable that goes into the IDE connector) and a 4-pin Berg power input connector, and a slimline floppy drive with the 4-pin Berg connector and a connector like the IDE, with less pins (computer noob here).
I can accept money orders/cashiers checks, or trade. In either condition, buyer pays shipping. If at all interested, PM me and i can give whatever pics needed, or other specs.
Thanks cheesey.
