  • Guests: 64
changing the voltage via controller
audio:deviant
Thu Oct 01 2009, 05:29PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
hello all,
im looking at adding another effect to the DRSSTC by controlling the voltage using a module. i presume this has been done, how does this work exactly?
Thu Oct 01 2009, 05:46PM
You don't need to do this.
Just vary the pulsewidth. This will give you roughly the same effect as if you varied the voltage and its much simpler.
Fri Oct 02 2009, 10:20AM
I've done it with a circuit similar to a lamp dimmer on the incoming mains. However, what Dr. Gigavolt said.
