  • Guests: 43
What's the best way to secure the ends of single layer windings on a plastic form?
1 2 3 4  last
jpsmith123
Tue Sept 29 2009, 09:52PM Print
Well I'm ready to wind my UHMW polyethylene tube coil formers with 30 gauge magnet wire, but I'm stuck on how to mechanically secure the windings on the form.
I've seen some people just using tape on the ends, but that doesn't seem like a very elegant solution to me.
I'm wondering, what do Tesla-coilers do? Is just varnishing the coil enough? Or maybe some kind of large diameter heat-shrink tubing?
doctor electrons
Tue Sept 29 2009, 10:09PM
Here goes! If the plastic that you are using (the uhmw) is clear, than this probably wont be what you want, if it is not clear try this.
You can use a 12 X 12 piece of double sided tack paper around the form; as long as it does not extend beyond your winding length. The paper is very thin and non conductive obviously so there will be no issue with hindering performance. Or just wind it as tight as you can and use some painters tape to hold the loose ends. Then coat it with polycrylic or polyurethane. That will hold it tight until it dries than you can finish the loose parts easily. If you wind the coil at a cold temperature and secure the ends when you warm it up the coil will tighten, thats the best time to coat it. Good luck, hope this helps!!
jpsmith123
Tue Sept 29 2009, 10:42PM
Thanks for the reply. Yes, I guess I'm going to have to coat it with something.
Has anyone ever used any Krylon "Sprayon" insulating varnish, as in the following link, and if so how did you like it?
Tue Sept 29 2009, 10:55PM
I use nylon nuts and bolts with a double solder tag as anchors in that kind of work, or even a ceramic stand-off with a nut on the inside of the tube.
aonomus
Tue Sept 29 2009, 11:18PM
I've used Minwax (I think) polyurethane varnish to coat the coils, and for the end terminations I used a nylon bolt at the base to connect a terminal up. Probably not the best, but not the worst solution.
jpsmith123
Wed Sept 30 2009, 04:01AM
Harry wrote ...
Hello Harry,
Plastic nuts and bolts were one of the first things that crossed my mind...and I'll probably end up using them, but I'm hesitating a little bit as I don't like the idea of weakening the insulating system somewhat by drilling through the coil former. If it were an air-core situation of course it wouldn't matter, but with the ferrite core, grounded-foil shield and only some thin PP insulating film inside, I had hoped to preserve the integrity of the thick plastic coil former.
Maybe I can rig up some kind of plastic clamp or something and secure the wire to it.
Wed Sept 30 2009, 06:53AM
I just apply a patch of superglue at the end (I try to get 10 windings or so at the top/bottom and sometimes in the middle for good luck) before I apply polyurethane, and as long as you don't yank on the wire to hard it holds just fine. it also give the added benefit that if you do yank the wire to hard, you just unwind one turn wink It also doesn't leave any sharp ends to cause bad e-field gradients.
Wed Sept 30 2009, 01:29PM
jpsmith123 wrote ...
Harry wrote ...
Hello Harry,
You can pull the larger cable ties up pretty hard with pliers. I think sometimes it's helpful to have what I'll call an initial anchor, which can hold down the end temporarily whilst glue or varnish dries and all is made safe.
Nicko
Wed Sept 30 2009, 04:17PM
I'm a bit of a beginner at all this HV stuff, but I use that nice adhesive copper foil to place a small patch (1cm x 1cm) at the end of the winding to act as a strain relief and solder pad - terminate the winding on that and solder the flying leads to the pads also...
Wed Sept 30 2009, 05:25PM
Nicko wrote ...
That would probably be good for fine windings Nicko, but when you get onto thicker wires that you have to straighten as you turn, I'd suggest a rather stronger anchor at the end.
I've been winding some inductors for a Pulse Forming Line using 3mm enamelled copper wire, (11 SWG) and holding down the end and getting a straight pull is no easy matter for the man with ten thumbs, even though there are not many turns.
1 2 3 4  last
