  • Guests: 69
Simple 2000V Microwave Power Supply
Aussienitro
Mon Sept 28 2009, 11:47AM Print
Aussienitro Registered Member #2399 Joined: Mon Sept 28 2009, 09:29AM
Hi fellas, Simple question, searched but the specific schematic here evaded me.
See attached picture. I need a 2kv power supply to charge a 2.5kv 1uF capacitor.
Few questions,
1. Is the picture fundamentally correct?
2. Where can I get a bridge rectifier capable of handling 2000 to 5000 volts? If no BR's are available what value diodes should I source?
3.Have I ommited anything that should be implimented?
4. A simple 240v lamp between the power outet and the transformer will show me when capacitor is charged, correct?
5. How can I measure the voltage at the capacitor? (multimeters I have max at 1000v, what should I look for?)
Thankyou.
1254138431 2399 FT0 2000vsupply
Mon Sept 28 2009, 12:03PM
With 2000V AC input, you'll get ca. 2800V DC on the cap.
You can make the bridge rectifier out ouf 1N4007 diodes, 5 per string, but for such a small cap, halfwave rectifier is enough, use 10x 1N4007's in series.
Otherwise its OK.
Bjørn
Mon Sept 28 2009, 12:45PM
You need a resistor in parallel with the capacitor to make sure the capacitor does not stay charged for a significant amount of time after the charger is disconnected.
It will show when it is charging, not if it is charged, a vital difference. Your "charged" detector must go in parallel with your capacitor.
Use a voltage divider Link2 , remember that the multimeter also has a resistance...
Also read this: Link2
Dr. Slack
Mon Sept 28 2009, 01:18PM
The lamp between the outlet and the MOT will current limit the charging process, a good thing. It will also hint at the value of the charging currnet, so will dim at the end of charge. As a MOT takes such a huge magnetising current, a primary lamp will not go out when charging is complete.
Even though a primary lamp will indicate that charging has finished, it doesn't hurt to monitor the capacitor voltage as well. When making a voltage divider, remember that the maximum voltage rating for normal resistors may only be 200v, so you should string several together in series to share the voltage between them, as well as to increase the resistance.
Aussienitro
Mon Sept 28 2009, 02:25PM
Thanks a lot fellas, understanding most so far, just trying to work out the voltage divider.
I measured the resistance of the multimeter which gave a value of 1.002MΩ. So I need to make up a 9.0MΩ resister placed in series on the positive lead running into meter and negative lead onto negative terminal of capacitor, thus dividing the voltage by 10 at meter. Is that correct?
Bjørn
Mon Sept 28 2009, 02:47PM
Yes, that is correct.
Mon Sept 28 2009, 04:36PM
Aussienitro wrote ...
I think 1 MΩ is uncommonly low for the resistance of digital or analog multimeters on 1000 VDC range.
So recommend that you test your meter-with-divider by measuring a known voltage, without changing the range selection on meter.
Also, pay attention to the power dissipation and voltage limit of your scaling resistor.
With the numbers you gave, if the meter were pegged the external R would have 9 kV and 9 watts.
Note to other commenters: the MOT will "fully" charge the 1 uF cap in a fraction of a second, so there's not much difference between a "power is on" light and a "capacitor is charged" light. I sure hope OP intends to disconnect the MOT and rectifier before a pulsed capacitor discharge. smile
Aussienitro
Mon Sept 28 2009, 04:51PM
Klugesmith wrote ...
Yep I'll be sure to give it a test beforehand, I'll attach the test I did. The cheaper one being measured was intended to be butchered and become integral part of the supply.
1254156664 2399 FT76776 Meterresistance
Also, pay attention to the power dissipation and voltage limit of your scaling resistor.With the numbers you gave, if the meter were pegged the external R would have 9 kV and 9 watts.
You've lost me here. What resistors would you recommend?
Aussienitro
Mon Sept 28 2009, 04:52PM
Wow, nope wasn't intending too. Whats the reason for this? Though it would be easy enough to do at the relay.
GeordieBoy
Mon Sept 28 2009, 06:55PM
Reverse voltage and/or RF from the discharge is likely to fry the rectifier.
