  • Guests: 65
Help, Building Coil Gun/ ETG
Sat Oct 03 2009, 05:14PM
kromsson wrote ...
rp181 wrote ...
It is a typo, the max capacitance for 450v is 9200uf, look at the datasheet.
Wrong, the datasheet is common for all caps. Look carefully at the datasheet, they say "look at the product specifications for actual values".
Why don't -you- look more carefully at the datasheet?
The link you posted is to a Mouser catalog page for Manufacturer Part #: DCMX632T450DG2B (in fact the p/n is in the URL), with a link to C-D's DCMX family datasheet.
Page 3 of the datasheet explains that 632 means 6300 microfarads.
The d/s lists 450 VDC caps up to 12000 uF and 500 VDC caps up to 9200 uF, but those extreme values might be made only when C-D gets a direct order -- they are not necessarily stocked by any industrial distributor.
Backyard Skunkworks
Sun Oct 04 2009, 07:27AM
I'm partial to using a stepup autotransformer off of mains for my coilgun projects. Its about the fastest and easiest charging option out there, as long as the goal is not for a battery operated gun.
I wouldn't be so fast to dismiss flash caps as a good bank, while they have their limitations, they are basically free and are designed for an application similar to coilgun use.
