MIG welder goes Kabloowie! fix?
Sat Sept 26 2009, 11:29PM
Registered Member #96
Hi all.
*THIS* is why you don't override safety cutouts on equipment. Owner said "it went bang and smoked a lot"....
Observe.
Any ideas? these parts are 4.7uF 400V wound capacitors.
the blown resistor is one of four, the other three seem OK and so do the FETs on this board.
-A
Sat Sept 26 2009, 11:35PM
Registered Member #543
replace the frazzled capacitors, the cement resistor and the burnt piece of wire, and start up under reduced power if you have a Variac.
