  • Guests: 64
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Increase output of SGTC
raff
Wed Sept 23 2009, 12:08AM Print
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
hi guys,
here is my latest setup of flyback driven SGTC.. 3"dia x 8.5" coil length x #30AWG wire.. cap is 2.5nF(home made).. topload is 1.5"minor x 5.5" major...topload minor should have been 3", but I dont have one right now... OR I could make another torroid topload..but thats gonna be sooner.. cheesey
1> can I possibly increase output arc length with having a higher value cap.. from 2.5nF ->>> 10nF?
2> w/c is a better primary, a flat pancake or helical??
EDIT: flyback driven SGTC
-Ralph
Andyman
Sun Sept 27 2009, 04:31PM
Increasing the cap size will give you more power, but that's only if the flyback is powerful enough to fully charge the larger capacitor. Also, remember you need to change the primary inductance if you add that cap.
For a small coil, a helical coil might get arcs to the secondary, so an inverse conical coil would be the best, and just experiment with the coupling to maximize power transfer.
Sun Sept 27 2009, 06:45PM
You can trade arc length for break-rate,
the limit is mainly spark gap losses.
e.g. I used a 1.4 W hv generator from a laser printer for 0.5 Hz break-rate
and got about 300mm (1 ft.) arcs to an earthed target.
raff
Sun Sept 27 2009, 11:08PM
hi guys,
thanks for the replies.
got them noted.. my to-do list for my sgtc:
#1> add another torroid , so this makes 2 of them.. my secondary is 3" ID.. my 1st torroid has minor dia = 1.35".. rule = diameter of secondary coil SHOULD BE EQUAL to torroid minor dia...
#2> make some more diy CAPS.. say 5nF so primary turns can still be in the 1-15T range, more than 15T for primary = LOSSY
#3> for starters, since im using DC supply for TC, Im also going to use a DC motor(fed with variable duty PS) for an RSG... or maybe an RQ SG? hmm
I hope my assumptions are correct
-Ralph
