  • Guests: 55
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
starting to build a DRSSTC
default
Sun Sept 20 2009, 04:26AM Print
default Banned on 9/23/09.
Registered Member #2374 Joined: Sun Sept 20 2009, 04:06AM
hi i am new here and i want to build a drsstc. i started in hvcomm but since not many people gave much attention i made a account. i am going to start slowly so i am starting with gate drive transformer smile i think it looks pretty good. here is a pic of it.
1253420698 2374 FT0 072709 004400
Sun Sept 20 2009, 04:58AM
Hmm, what material did you use for the transformer? For a DRSSTC you will want to use ferrite, that looks like a piece of steel.
default
Sun Sept 20 2009, 03:17PM
hmmmm why do i need ferrite? i tested this ring with a magnet and it is magnetic, i thought thats all that matters?
Avi
Sun Sept 20 2009, 03:51PM
The type of metal determines how much magnetic flux it can hold, and how fast the material will allow the field in it to be changed.
Here is a rendering I have made that shows the basic idea of GDT construction
http://wiki.4hv.org/index.php/Image:GDTWinding.png
One coil is driven, the other 4 connet to MOSFETs or IGBTs.
For more details see Link2
Austin
Sun Sept 20 2009, 09:14PM
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
Avi wrote ...
does twisting the 5 wires together reduce the amount of leakage?
StevenCaton
Sun Sept 20 2009, 09:25PM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
hi i am new here and i want to build a drsstc. i started in hvcomm but since not many people gave much attention i made a account. i am going to start slowly so i am starting with gate drive transformer i think it looks pretty good. here is a pic of it.
Have you built a TC before.
default
Sun Sept 20 2009, 09:36PM
I made a driver for the GDT Is this a good waveform?
1253482559 2374 FT76274 092009 125400
Sun Sept 20 2009, 09:55PM
No, it's not.
I would suggest you to first read some theory, and if this is your first coil ever, I would start with something much less complex - such as a spark gap coil or a simple SSTC.
default
Mon Sept 21 2009, 03:00AM
I made a ISOTOP bridge today. they are ixgn60n60c2d1 that is what dan recommended for minibrute. here is a pic
1253502028 2374 FT76274 092009 225500
Avi
Mon Sept 21 2009, 04:17AM
default wrote ...
That is not a square wave, so no.
default wrote ...
That has way too much thermal paste and is not even mounted. would not even bother with heatsinking it until you have tested its waveforms to be suitable
