  • Guests: 56
first light :) 900w coil
eniyuki
Sat Sept 19 2009, 05:26PM Print
eniyuki Registered Member #2148 Joined: Tue Jun 02 2009, 02:22AM
hi i started firing up this coil lately and pleased with the results (maybe?)
im getting 31" aprox. spark length with no ground target.
still this coil is yet tuned and needs more fine tuning.
any tips about tuning tesla coils?
can i really achieve 50" sparks based on my calculations in javatc?
specs:
15kv@60ma
sucker gap
3x12 spun aluminum toroid
0.015 uF CDE caps (0.023uF when measured using multimeter..WHY!?)
4.5"x18" 25awg secondary
tap at 9th turn primary.
LEDs giving off a lil light without power.
anyway heres the video.
doctor electrons
Sat Sept 26 2009, 03:03PM
Check the tolerance on your caps. You can do the math including the tolerance and see if
that is the reason you measure .023uF instead of the marked .015uF
Nice video! That is a very sweet little coil, nice work!
Herr Zapp
Sat Sept 26 2009, 06:45PM
electrons -
I believe Eniyuki is talking about the capacitance value of his entire MMC assembly, not the value of a single capacitor. If I recall, he used C-D 942C20P15K capacitors, which are rated at 0.15uF, not 0.015uF.
Eniyuki -
I suspect measurement error. What type of instrument are you using to make your capacitance measurements? What is its rated accuracy on the capacitance range you are using? Also, do you have bleeder resistors across each capacitor?
I have a quantity of unused C-D 942 caps, 0.15uF at 2,000V from several different C-D manufacturing lots (different date codes). I measured 25 parts using a laboratory-quality Fluke 87-III multimeter, which allows "zeroing" out of the test lead capacitance.
Of the 25 parts measured, the highest value was 0.151uF, and the lowest value was 0.149uF.
This is very small part-to-part variation in capacitance value, and shows very good manufacturing process control.
Regards,
Herr Zapp
eniyuki
Sun Sept 27 2009, 05:49AM
Herr Zapp wrote ...
electrons -
Eniyuki -
Regards,
Herr Zapp
herrzapps right
i measured the total capacitance of my MMC.
im using a digital multimeter. dont know the brand but not as sophisticated as fluke.
i measured 1 cap and reads .151uF
i put a bleeder and measured it again and now reads .233uF
Sun Sept 27 2009, 06:33PM
Yea, bleeder resistors will change the capacitance. Idk how 10megohms is enough to change it *that* much :P.
A dead capacitor would raise the capacitance in a series string, and a capacitor that failed, then 'healed' would have lower capacitance. Not sure if either is the case, though.
raff
Mon Sept 28 2009, 07:08AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
eniyuki,
so thats why the change in capacitance (because of the parallel resistor bleeder/s)
Herr Zapp
Mon Sept 28 2009, 04:32PM
Arcstarter -
"A dead capacitor would raise the capacitance in a series string, and a capacitor that failed, then 'healed' would have lower capacitance."
It might be more accurate to say that a "shorted" capacitor would increase the capacitance of a series string, and that a capacitor that had had been severely overvoltaged many times, and had suffered dielectric punctures with "clearing" and loss of electrode area, would decrease the capacitance of a string.
In Eniyuki's case, the inaccurate capacitance measurement of his MMC is due to the effect of the bleeder resistors in parallel with each capacitor.
Regards,
Herr Zapp
eniyuki
Tue Sept 29 2009, 12:03PM
thanks Herrzapp for clearing things up but both of you seem clear to me.
ANYWAYS
i uploaded a new video of my coil
i think it is tuned because streamers became longer and THICKER
36" streamer, 41" ground target
is this coil already achieving its optimum performance of 900 watt PSU? or no?
Coronafix
Tue Sept 29 2009, 10:39PM
Great work Eni, nice to see it fully operational.
Well done!!
Herr Zapp
Wed Sept 30 2009, 02:16AM
Eniyuki -
Great job! That is a beautiful piece of work, and the performance is very good.
This is a perfect example of the results that can be obtained by taking the time to do the required research, and then assembling the coil with craftsmanship and attention to detail.
A few questions:
1. What is the strip of aluminium foil on the floor to one side of the coil? Is this a counterpoise?
2. If the aluminium foil is not a counterpoise, what are you using as an RF ground?
3. What is the gap spacing that you are using in your sucker gap?
4. What is your next step with this coil? More tuning, more input power (another NST), or ???
Regards,
Herr Zapp
