  • Guests: 436
Ryan Parle (44)
paulj (29)
Golasekk (48)
10/10 Ryan Parle (44)
10/10 paulj (29)
10/10 Golasekk (48)
Kaizer DRSSTC I
first  3 4 5 6
Coronafix
Sat Sept 11 2010, 04:38AM
Your work is stunning Mads!!!
Sun Oct 17 2010, 09:59AM
FIRST LIGHT!
Check out the first post for pictures of test and video from first light!
I AM HAPPY :D
GluD
Sun Oct 17 2010, 09:21PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
Sure looks good cheesey
dingo27
Wed Oct 20 2010, 02:22PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Nice coil, but...
Mads Barnkob wrote ...
With all the wonderful theory about GDTs in the wiki, it would be a shame not to check it out instead of just going for a high permeability core with 10 turns on CAT5 cable. So here goes
1255545675 1403 FT1630 Img 2683
Its a Epcos ringcore, material: N30, good up to 5MHz, Aemm^2: 95,89, AL: 5750nH
Inductance with 10 turns: L = AL * N^2 = 5750 * 10^2 = 575 uH
...on pic there is actually 11 turns, no?
Thu Oct 21 2010, 08:34AM
dingo27 wrote ...
Nice coil, but...
At most 10,5 :)
But it doesn't matter, it works like a beauty!
Thanks for the kind words from all of you :)
Thu Oct 21 2010, 11:42AM
It's impossible to have a half turn on a toroid core! :P
Every time the wire goes through the hole in the middle, that is one turn.
Coil looks nice btw smile
Raka
Sat Oct 23 2010, 09:23PM
Raka Registered Member #1838 Joined: Tue Dec 02 2008, 06:01PM
Steve will you please explain to me why you say that it is impossible to have half a turn on a toroid? I find that a toroid with a conductor just passing straight through the middle have significantly less inductance that when the conductor loops through the toroid (still passing only once through the middel)
ScotchTapeLord
Sun Oct 24 2010, 02:05AM
I wondered the same thing at one point. There is some bit of explanation here: Link2
My thought is that the extra inductance is leakage due to wire geometry.
Luca
Sun Oct 24 2010, 08:47PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Raka wrote ...
That's not true. Only the part of the conductor that pass into the "hole" of the toroid creates magnetic flux into the core. The parts of the coil which stay out of the hole does not create flux into the core.
regards,
Luca
Raka
Mon Oct 25 2010, 07:13PM
Thanks for the link Scotch. It helped, although I stil find it very un-intuitive.
Luca, Ill start a new thread in the general Science and Electronics forum to post snapshots of the test setup I used, if you would like to explain it further.
first  3 4 5 6
