  • Guests: 49
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
200MHz 4ch oscilloscope in AUSTRALIA
ragnar
Thu Sept 17 2009, 11:15AM Print
Hi guys,
First of all, thanks for looking. This oscilloscope cost $7,000 new, and you have the opportunity to get it for a fraction of that. The unit has been calibrated and has served well for years with no issues whatsoever. I kept it out of the sun so you don't have to suffer yellowed plastic.
Feel free to snipe it on eBay, item #260478426977 or send me a private message.
Big
There are no potentiometers to get scratchy on this oscilloscope; ALL of the front panel controls are digital, velocity-sensitive rotary encoders. You won't find another one quite like this.
  • Made in Holland
  • 200MHz to DC bandwidth
  • 4-channel operation
  • Digital frequency/voltage readout
  • AUTOSET button
  • 2mV/div vertical sensitivity
  • 2nS/div horizontal timebase
  • Automatic risetime cursors
  • RS-232 interface
Worldwide bids welcome, but if you live within Sydney, save the postage - I can deliver this to you! Just send me a message with your location.
You get all of the following:
  • PM3092 oscilloscope
  • 10:1 probe
  • operating guide
  • reference manual
  • protective front case
And rather than just rattle off the manufacturer's specification, here are other features you will actually enjoy
  • Delayed timebase on all four channels
  • 10 stored setups in non-volatile memory
  • Self-calibration button for temperature compensation
  • Bandwidth limiting function (20MHz -3dB)
  • Digital vernier adjustment on both X and Y axes
  • 100V-240V, 50Hz-400Hz input
  • Z-modulation at rear
Front Probe
Manuals
Thu Sept 17 2009, 08:54PM
Best of luck with the sale, that quite a nice scope there!
ragnar
Fri Sept 18 2009, 02:21AM
Thanks! I'm hoping to invest in a more expensive DSO I can carry overseas wink
Hazmatt_(The Underdog)
Fri Sept 18 2009, 09:11AM
I would bid.. but knowing my mailman, he would drop it over the fence again!
ragnar
Sat Sept 19 2009, 06:01AM
You can probably find cheaper ones closer to home; scopes tend to be expensive in Aus :(
ragnar
Thu Sept 24 2009, 01:26PM
Here are some waveform photos by request. The second waveform (motor controller circuit) would be uncapturable if not for the invaluable holdoff function (usually reserved for expensive digital scopes.)
Hook most of the other scopes on eBay up to fast circuits, and they will tell you more about the oscilloscope than your circuit! This one has the bandwidth to show the detail you need for serious RF work.
Wave1 Wave2
Clip Iec
Yes, if you really care, the IEC cord and the special banana/parrot-clip for grounding are included - it's all yours. Feel free to drop me a line if you're looking for delivery tongue
ragnar
Fri Oct 02 2009, 09:46AM
This sold on eBay, and I suspect the buyer was not from 4HV -- feel free to close this thread.
