  • Guests: 50
What is it?
Alessandro
Sat Apr 15 2006, 11:49AM Print
Alessandro Registered Member #70 Joined: Thu Feb 09 2006, 08:19AM
I thought it might be a fun idea to have a "What is it?" thread.
Simply post a unusual, interesting or mysterious picture, add a clue or two if you like and then allow other members a chance to guess what it is. Lets keep to one picture at a time though. No photoshopping either.
I'll get it started, the only clue at this point is that it's high voltage related.
Exposure time is 1 second.
1145101582 70 FT1630 Pic1
Desmogod
Sat Apr 15 2006, 01:04PM
Is it an HV discharge on water?
Outstanding photo, I want it full size as a background.
ragnar
Sat Apr 15 2006, 02:42PM
'Kirlian photography'...?
aahz
Sat Apr 15 2006, 03:21PM
aahz Registered Member #186 Joined: Thu Feb 16 2006, 07:22AM
Jellyfish!
Seriously though, it's a picture of a nebula with stars (No hearts or horseshoes though)... that you took with a HIGH VOLTAGE CAMERA! (in order to satisfy the clue)
Sat Apr 15 2006, 03:24PM
Yea, it's a jellyfish that nibbled on an undersea cable! smile
Michael W.
Sat Apr 15 2006, 03:42PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
A tangle of corona emitting wire and the spots are just photography artifacts...?
Electroholic
Sat Apr 15 2006, 06:30PM
I agree with force lab about the corona wire.
but that intensity dots seems to follow the inverse square law.
[dictance from the wire/UV]
so my guess would be fluroescent dust?
Alessandro
Sat Apr 15 2006, 09:53PM
Yes, that is corona, but it's not emitted by a wire.
The spots are not photography artifacts,
nor are they bumps or grounded points on a surface,
or some sort of fluorescent dust. Hint: some variants of the
material that causes those spots are superconductors,
and some also widely used in many components.
Edit: Forgot to mention, the scale is quite small, those dots are only a couple of millimeters in diameter.
Marko
Sat Apr 15 2006, 10:19PM
That 'corona wire' seems to be the trace of some breakout point moving fast around.
That particles are interesting, they seem like result of some kind of explosion or (?) microwaving.
Alessandro
Sun Apr 16 2006, 12:17AM
Firkragg wrote ...
Yes, correct, the corona is caused by a single breakout point moving around quickly.
Now, what's with those glowing spots?
