  • Guests: 74
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Any experience with this caps? Epcos 683PPB202K?
Dominick
Fri Sept 11 2009, 11:01PM Print
Dominick Registered Member #2357 Joined: Fri Sept 11 2009, 10:44PM
I was curious if anyone has had an experience with these caps. They are the Epcos 683PPB202K. The stats on them seem pretty good:
Metallized Poly Film Cap
Vrms: 700
VDC: 2000
dV/dt (V/us): 2,200 @15nF
I was think about getting these as they are an instock item on Digi-Key (495-3234-ND) and sell for .77/ea. Just wanted to know what anyone thinks of these before I go and buy some. Thanks in advance.
Herr Zapp
Sat Sept 12 2009, 04:48AM
Dominick -
Without knowing EXACTLY what you intend to use these capacitors for, it's impossible to render any advice on their suitability for that use.
If you intend to use them as small paperweights, they do have an attractive blue color.
Otherwise, please specify what your intended use is.
(If you intend to use them in any type of RF circuit, you did review the frequency vs voltage derating curves, right??)
Regards,
Herr Zapp
