  • Guests: 29
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Secondary Grounding
EvilTesla-RG
Thu Sept 10 2009, 05:02PM Print
EvilTesla-RG Registered Member #1523 Joined: Sat Jun 07 2008, 02:05PM
I am currently working on a Tesla Coil for a chemistry professor.
And I am trying to figure out how I want to ground the secondary.
My first coil I grounded the normal way, I had a stake I could drive into the gound.
My second coil I just took the chance and grounded it into the house wiring.
But niether is very acceptable here. This coil is to be built on the third floor, and although it will be small and mobile, I really don't want to rely on the weather outside everytime we try to start up the coil.
I don't want to plug in to the wall...for obvious resons.
I could just not ground it.....but that would limit the coil's preformance...which is key.
Is there anouther option? Is there some filter I could through put on the end of the secondary so I could just ground it?
I do inteand to ask my Professor what he wants to do, but I'd like options.
EDIT: Just talked to professor, he sugested that I use the water pipe system. However, after running this by an electrician (of sorts) he sugested that this might turn the intire building into a radio transmitter if the water pipe system isn't properly grounded.
StevenCaton
Thu Sept 10 2009, 07:16PM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
When I demonstrated my TC for my high school physics class, I just used the water pipe system to ground it. It will work.
what?
Curtis
Thu Sept 10 2009, 07:19PM
Curtis Registered Member #883 Joined: Sat Jul 07 2007, 01:02PM
anything with a large enough capacitance will work. maybe a large metal table ?
EvilTesla-RG
Thu Sept 10 2009, 07:26PM
Hmm...alright
so any large metal object,
and the water pipe system should work fine?
Mates
Thu Sept 10 2009, 08:07PM
Water pipes are OK (according to the building safety procedures they must be grounded and even if they wouldn't be nothing bad can happend). You can also have a look outside the windows - if you lucky there might be the lightning conductor nearby which would be the best solution... good luck!
Thu Sept 10 2009, 09:11PM
Dennis Rogers Registered Member #1837 Joined: Tue Dec 02 2008, 02:20PM
Agreed. I work in construction and here in NYC you can't even bring power into a building until the water mains have been run. (For the purpose of grounding). All trades run off of gasoline generators if the water mains are not installed.
Dennis
StevenCaton
Thu Sept 10 2009, 09:43PM
Hmm...alright
It will work fine. Good luck with your demo.
EvilTesla-RG
Thu Sept 10 2009, 10:34PM
Awsome!
thanks!
I'll probably go with the water pipe system then.
raff
Fri Sept 11 2009, 10:15AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
LARGE (3ft diameter) aluminum tub also works as good "grounding" if no EARTH ground is available
Avi
Sat Sept 12 2009, 02:49PM
Curtis wrote ...
thats what i do. just do NOT touch it or have sensitive components on or near it
