  • Guests: 75
MO diode data help needed.
Mon Sept 07 2009, 03:01PM Print
I've only been able to find the sketchiest data on MO diodes, despite prolonged Googling.
For example, all i could find out about HVR1X7 was "microwave oven diode 12kV 550mA."
Should I understand this as 12kV PIV, RMS or actual maximum working voltage?
And what values should we assign to a "universal" MO rectifier?
Thanks in advance for any certain knowledge or suggestions,
Harry.
Plasma Lover
Mon Sept 07 2009, 05:23PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
Hello Harry,
In my experience, MO diodes can be run for short periods (less than two minutes) at over 2A, though they tend to get 'quite warm'. The diodes are conservatively rated, obviously, and are usually able to take 15KV peak voltage (I have ran an OBIT rated 10KVRM 23mA through them successfully for extended periods).
It seems that MO diodes have a certain point where they will fail due to too much current; this point seems to be around 6A, even in short pulses. I have ran multiple MO diodes on a current-limited source rated at 36V at 20A, continuous. I ramped the voltage up slowly, and decreased the inductance that caused reactive current-limiting when the voltage was full. When I managed to get the current up to 6A, the poor diode didn't just release its smoke, it exploded in a manner that can only be likened to a miniature glass bottle containing dry ice and water, though the sound could be likened to a firecracker going off on one's shoulder.
I hope this clears things up and reminds you to wear safety glasses when working with these components.
Good luck with whatever project you are pursuing. =)
- Christopher
Mon Sept 07 2009, 07:12PM
Thanks for that, Christopher,
I 've found a UK supplier of MO diodes - which they characterize as "HVR1X7(HVR3H)" - for just £1.60 each (~US$ 2.60) which is very cheap by UK standards. Elsewhere, I found that these diodes are described as "12kV 550mA"
I'm building a C&W unit which is to be epoxy potted, so if any of the components are under-rated and fail, the whole thing will be a costly write-off.
It is a full-wave C&W powered by a 4kV-0-4kV transformer, so the question is whether two MO diodes in series, or three diodes in series, plus anti-surge resistors, are needed for each leg of the multiplier to give a very very low chance of failure even after many hours of continuous operation at low currents (5mA max)
