  • Guests: 31
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
tank capacitor contruction for induction heating
Hernan
Fri Sept 04 2009, 12:31PM Print
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
Hi guys, I decided to start this thread because I want to make a tank capacitor for my own LC series induction heater.
I ´ve got 54 vishay sprague 715P capacitors rated at 0.0033uF 600Vdc/500Vac so the total tank would be 0.1782 uF with a work coil of 4.6uHy the resonant freq. is about 175Khz.
fortunately I could find the datasheet on web . the derating curves says that I could put a maximun of 400Vrms aprox at the resonant freq. so the maximun currrent for each cap would be:
with C= 0.0033uf and Freq 175Khz
Imax = Vmax/ Xc= Vmax . 2 . PI . Freq. C = 1.45 Amps rms each cap
1.45 . 54 = 78.3 amps for total
Are the above calculations correct?
my question is how can I solder them for proper current sharing between them and the possible setup for water cooling
I 'll estimate your comments
regards
Hernán
]sprague_715p.pdf[/file]
Gabriel35
Fri Sept 04 2009, 05:11PM
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
I think that if they will be immersed in water, a "S" or "U" setup will work nice, with acceptable space occupation.
Fri Sept 04 2009, 08:51PM
General principles;
- Bus conductors should be as short and wide as practical to minimize inductance
- Each capacitor should 'see' a similar path to the load,
e.g.1 Good
1252097090 162 FT75446 Capbank
e.g.2 Bad
1252097302 162 FT75446 Capbank2
In the second diagram the left-most capacitor will be stressed more than the right-most one, whereas in the first diagram all capacitors will suffer the same !
Fri Sept 04 2009, 09:30PM
Wouldn't it be less effort, and cheaper, to simply buy a capacitor of that size and rating?
Fri Sept 04 2009, 09:41PM
Not if you can get a deal on smaller capacitors in bulk, which is easy. A single capacitor suitable for induction heating, or DRSSTCs for that matter, are hard to find and cost dearly. I squeezed a quote out of Celem for a conduction cooled power capacitor, which I've attached. It cost as much as all of my projects over the last year combined. The 100 mini capacitors I used in my induction heater have worked alright, and only cost about 20 dollars with shipping.
]qut20007.pdf[/file]
Hernan
Fri Sept 04 2009, 10:43PM
thanks all for the replies
I thought in two cooper discs and the caps between them but the radius must be 90mm to contain the 54 caps. but is a problem to find the discs.
I like the first scheme proposed by Sulaiman because is easy to build with cooper strips.
I agree with Eirik the cost of mine was u$s 15 for the 54 caps compared with u$s300 from one conduction cooled capacitor
But in future I plan to buy some of them
regards,
Hernán
GeordieBoy
Sun Sept 06 2009, 05:05PM
I'd mount all of the PP/foil capacitors in parallel between two solid aluminium blocks. You could take the leads through the blocks and secure on the outside with mounting hardware. Seal the holes and fill the gap between the blocks with your circulating water.
If you keep the lead lengths as short as possible you will minimise the lead resitance and get what little conduction cooling you can through the capacitor leads. The problem is that capacitor dielectric (plastic) and typical capacitor packaging (also plastic) really don't allow the heat to get out, so most cooling will be through the leads.
That's why dedicated IH caps use special design to support conduction cooling.
-Richie,
Hernan
Mon Sept 07 2009, 03:11AM
Richie, your idea to remove the heat of the dielectric of the caps is very good so I 'll need to use distilled water between the blocks ?
I thought to use a container with silicone fluid and submerge the caps on it. then put a cooper tubing with circulating water to cool the silicone like a heat exchanger but I don't know if this setup will remove the heat properly.
regards,
Hernán
Mon Sept 07 2009, 03:21AM
Vegetable dielectric oils such as ordinary kitchen sunflower seed oil, or rape seed oil, will do fine. (Google "vegetable dielectric oil" if in doubt!)
You could keep this cool with a Peltier device if you have the amperage to spare! smile
Mon Sept 07 2009, 05:03PM
