  • Guests: 69
Marx generator resistors
Tonskulus
Fri Sept 04 2009, 08:28AM Print
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Im making 20-stage marx generator using 1nF/15kV ceramic capacitors. I have finished first 6 stages and its working very good. Maybe 12cm sparks. Powersupply is simple NE555+mosfet+modern flyback transformer giving 20kV (more than enough). Resistors are two 680k/2W in series. Problem is that i have no more left those 680k, I only have some 390k, 560k, 820k similar resistors.
So my question is that:
How important it is to have same value for all resistors? Lets say I have now 2x680k = 1.36M, is it good idea using 2x560k or even more, 2x820k resistors for final stages? Actually I dont see any problems with that but is that so?
Fri Sept 04 2009, 10:10AM
For your purpose, it won't make any difference.
mikeselectricstuff
Fri Sept 04 2009, 06:39PM
The most important thing is to use resistors that have good surge capability - film types (even HV ones) don't last long. Solid carbon composition ones are ideal if you can find them. Value isn't too critical, but if you use a mix, put the lower value ones nearer the charging end as you are charging more caps through these than the ones further up.
Fri Sept 04 2009, 08:16PM
The choice of resistors should be based on the desired time-constant and output impedance of the Marx. Ultra fast Marxes usually employ wire-wound components of 50R or so.
Tonskulus
Fri Sept 04 2009, 08:59PM
Ok, i have now 2x560k resistors at lower part of marx and 2x390k at top end. How ever, it works....for a while.
It fires few times and then stops working. Reguires some time to work again, why is that happening? Too much corona losses ionizing surrounding air that prevents all caps to fully charge?
However, there is now 16 stages, 30-35cm sparks.
Spark gaps: first and second gap is set to 10mm, rest ones around 6mm.
Tonskulus
Sat Sept 05 2009, 10:35AM
I just made some improvements. Now it works better but still stops working after a while...
Picture and video now available here:
http://www.elisanet.fi/tonskulus/marx1.jpg
http://www.elisanet.fi/tonskulus/marx.wmv
Sat Sept 05 2009, 10:44AM
Have you thought of measuring the resistance of all your resistors after the Marx has failed?
My guess - and it is only a guess - is that the voltage developed across such high resistances exceeds their maximum working voltage, and that one or more of them has been destroyed, and gone open circuit, or grossly changed its value.
What is the maximum working voltage of the resistors? Are they special high voltage types?
Tonskulus
Sat Sept 05 2009, 11:27AM
Harry wrote ...
It cant be resistor failure because it is still working. It just fires few times maybe 10-15seconds and then stops. After that I just switch powersupply off for few seconds and then back on and it works again. I dont know working voltage ratings for those resistors..
Sat Sept 05 2009, 01:01PM
Tonskulus wrote ...
Harry wrote ...
Then the value of the resistors is too high, and after a few firing sequences a state of equilibrium is produced.
Tonskulus
Sat Sept 05 2009, 01:04PM
One Mohm / stage...is it really too high? I have seen many similar marx generators that has 2.2Mohm resistors without any problems.
