  • Guests: 29
Drsstc strange behaviour
mmt
Thu Sept 03 2009, 03:38PM Print
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
Hello,
I currently working on medium size drsstc and it dont works as i expected, I have 38cm long secondary, I'm using this steve's driver Link2 with dual ucc's. I made a full bridge of HGTG30N60B3D, with 15V zeners on GS and 1N5819 paralel 10ohm resistor on Gates. It makes only about 1cm long sparks to ground on 24VAC, of course i tried tune circiut and this is the best result i get. I afraid when i connect this coil to 230VAC the bridge will blown as it dont work properly..
Can anyone help me?!sad
Bennem
Fri Sept 04 2009, 08:15AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi mmt,
Have you scoped any signals yet?
what mmc value have you chosen?
and what interrupter frequency and pulse width are you operating at?
i would put your coil dimensions into JAVATC and see what
tuning point it comes up with.
i had the same problem when i built my smallest DRSSTC
and it turned out to be a faulty UCC due to one of anti-latchup diodes
on the output pins (6&7) being dry jointed.
All the best,
Mel
mmt
Fri Sept 04 2009, 12:44PM
i am a poor man i dont have any scope or freqence meter, only one basic mulitmeter...:( and my mmc is another strange thing, Iam using one simple program for some TC calculations and it says my MMC value used to be 167nF so i put there one and sparks length was wery small, so i put there more of them and it seem the more I put there the bigger sparks i get but i stoped at 1uF witch is absolutly different from my calculations and with this cap I get the biggest sparks.. Iam using this interrupeter here Link2 with max ON and OFF time pots resistance, My resonant freqence is 123,56 kHz and calculated MMC is 167nF. and here are all my coil preferences:
Primary
coil dia: 18 cm
wire(pipe) dia: 6 mm
#turns: 7
height: 7,7 cm
Secondary
coil dia: 11 cm
coil height: 38,5 cm
wire dia: 0,2 mm
Toroid
ouside dia: 26,6 cm
ring dia: 4,5 cm
