  • Guests: 73
(Probably) A Stupid Question
SpaceWyzard
Fri Aug 28 2009, 01:28AM Print
SpaceWyzard Registered Member #2318 Joined: Fri Aug 28 2009, 01:22AM
This question most likely has an obvious answer that is eluding me, but I shall ask anyway. In a normal tesla coil, the high frequency is generated by the capacitor repeatedly and rapidly discharging through the spark gap and primary coil. This is all done on the HV side of the circuit, rather than on the wall current side. Why then, could the high frequency pulse not be generated on the 120v side with a similar mechanism, just at much lower voltage, and THEN be fed through the HV transformer to the primary coil?
J. Aaron Holmes
Fri Aug 28 2009, 02:34AM
First off, the high frequency is not generated by the rapid discharge of the capacitor through the gap. The high frequency is generated by the "ringing" of the primary tank circuit, which includes the cap, gap, and primary of the Tesla coil. One sort of serviceable analogy is a tuning fork: Think of the gap firing as if you're striking a tuning fork.
As for sending the high frequency through a transformer, a Tesla coil *is* the high frequency transformer. The primary/secondary assembly steps up the high-voltage, high-frequency current in the primary many times, resulting in the cool streamer discharge. However, a transformer of the sort most people use to charge the capacitor in a Tesla coil (e.g., a neon sign transformer, pole pig, etc.) is meant for 50- or 60Hz AC from the mains. Its construction simply doesn't allow effective transformation at Tesla coil frequencies.
However, there is the "OLTC," which Steve Conner, one of our esteemed moderators, can go into some detail about (I expect there's information in the HvWiki on this topic, too). In this Tesla coil topology, there is no transformer for charging the primary capacitor. Rather, the capacitor is charged directly off the mains, and various solid state devices effectively replace the spark gap. Not a trivial task to build, however.
Well, that's a start, anyway.
Cheers,
Aaron, N7OE
SpaceWyzard
Fri Aug 28 2009, 05:50AM
thanks, that really clears things up for me
btw, my friends and i just got our first coil working tonight putting out ~11 inch streamers
so happy
J. Aaron Holmes
Fri Aug 28 2009, 03:07PM
duroo wrote ...
Good to hear, and welcome to 4hv, by the way. Drop some pictures here when you get the chance. Everybody here likes to see sparks (as long as they're coming from the right place!). smile
Cheers,
Aaron, N7OE
