  • Guests: 30
Rollng a one ton concrete block
StevenCaton
Tue Aug 25 2009, 04:04PM Print
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Hi Guys. Here is an awesome project that my friend and I built last weekend. Its called a "round road" It allows one to physically roll a 2000 pound concrete block, because the odd shape of the road keeps the blocks center of gravity moving in a straight horizontal line. Because of this, you never have to lift the block.
I came up with a new invention that will allow me to use the same round road segment and move the block anywhere, and in any direction. I will be working on that invention this week. It should end up really neat.
Once again, that chunk of concrete weighs 2000 pounds.
Bored Chemist
Tue Aug 25 2009, 05:26PM
Neat, but remember that anyone who gets in the way of a ton of moving concrete is still in the way of a ton of concrete even if some timber is holding it up.
Renesis
Tue Aug 25 2009, 08:38PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
This is going to end up as one of NGC's "Think again"-comercials. cheesey
Tue Aug 25 2009, 09:33PM
Very cool.
Might have been handy for some of my friends doing repairs on the Pacific Crest Trail last weekend:
Wed Aug 26 2009, 01:00AM
SteveC wrote ...
It could have major applications in industry and contruction. Good luck with it! smile
aonomus
Wed Aug 26 2009, 02:21AM
I remember seeing a program on TV about someone demonstrating moving stonehenge sized rocks with simple leverage and physics, similar to this. Good to see that people can still think of these things instead of applying more power via hydraulic machines.
Wed Aug 26 2009, 04:17AM
100% agreed. Usually today's scientist's attitude would be expected to be something like "Why do something so simple when we can make it over-complicated because using technology makes you thmart hur dur".
I honestly wish i could woodwork half as good as that.
Good job, and sweet idea cheesey.
StevenCaton
Wed Aug 26 2009, 05:59PM
1251309547 1845 FT74988 Montyhall 3
1251309547 1845 FT74988 Montyhall 4
1251309547 1845 FT74988 Montyhall 5
1251309547 1845 FT74988 Montyhall2
1251309547 1845 FT74988 Montyhall 1
Tesladownunder
Sun Aug 30 2009, 08:06AM
Nice replication. Here is the YouTube showing this technique by the man who uses simple levers to position 22,000 lb blocks on his own.
Pretty remarkable stuff.
StevenCaton
Sun Sept 20 2009, 09:40PM
Ok, my prototype is done. My addition would allow someone to move the block anywhere, and in any direction, using the same round road segment.
How it works: The idea behind my addition is to somehow get the weight of the entire mechanism (road and block) onto a single pivot point. When this is accomplished, one can simply rotate the entire system with the push of a hand. When a large amount of weight is concentrated on a small area, the friction becomes negligible, and rotation is simple, even if the object weighs several tons. So what I do is use the weight of the block to lift up my round road. The block moves about 14 inches past a pivot point, (which is a 7/8'' track bolt) and this lifts up all of the road on the other side of the pivot point. Now the weight of the whole system (2325 lbs.) is on the bolts head. I can rotate the road wherever I want.
If a pivot mechanism was built on each side, one could roll the block to one end, rotate the road 180 degrees, then roll the block to the end again, then rotate 180 degrees again. One could advance the block 14 feet every time.
YOUTUBE VIDEOS (In the videos there is an additional 300 pounds of concrete blocks on the big block to get the thing perfectly balanced, this was a temporary fix. )
EDIT: Right now, there is only one pivot mechansim. To get the system totally working, a pivot is needed at each end, but I just wanted to build 1 first.
