  • Guests: 42
01/13 si2030 (62)
82H5270 LCD Datasheet
Andrew L.
Sun Aug 23 2009, 05:04PM Print
Andrew L. Registered Member #515 Joined: Sun Feb 11 2007, 02:06PM
I've been looking all around the web to find the datasheet alldatasheet, datasheetcatalog, google, ...
I need the pinout for this LCD panel, so if anyone has the datasheet I would be very greatful.
It's an IBM 12.1-inch (1024x768) XGA TFT LCD Panel Mfr P/N 82H5270.
I can post some pictures if needed.
Thank you
Sun Aug 23 2009, 06:52PM
That looks like an IBM part number. So, I guess the controller PCB on the panel will probably have been made by IBM or specially for IBM. Either way, the pinout very probably won't be published.
I suggest you pull it apart and look for chips on the controller board that you recognise. For instance a LVDS transceiver, there are only a few different kinds of these. Then get the datasheet for it, get your meter on the continuity test function, and go to work.
Andrew L.
Tue Aug 25 2009, 10:47AM
Yes it's an IBM laptop LCD screen.
What kind of connection is there between the motherboard and the LCD ?
Is it VGA or somethig else
Tue Aug 25 2009, 10:56AM
Probably LVDS Link2 plus a few other wires for power and backlight control.
Andrew L.
Wed Aug 26 2009, 01:02PM
Ok so to connect this LCD to VGA I would need a VGA to FPD-Link converter ?
