  • Guests: 44
Cheap Enamelled Magent Wire
Austin
Sun Aug 23 2009, 02:22AM Print
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
Where do some of you guys go for some cheap Magnet wire. I would like to find a local store in Oregon but I may have to find it online. I checked some of the obvious places like Ebay, But I need just a little bit over 5000' and the 12000' rolls are way to expensive. rolleyes
*Fix*
guh sorry forgot the gauge 26 AWG
rp181
Sun Aug 23 2009, 02:33AM
You didn't specify guage.
You can go to wire companies like MWS wire, and they will cut how much you ask for. I have gotten 2400' of 24AWG, and 200 feet of 18 AWG litz from them.
If that won't work, find a motor rewinding place. They might cut of a section for you.
Austin
Sun Aug 23 2009, 02:49AM
Thanks RP, I updated the post with the correct gauge size needed. I also requested a quote for the the desired length.
I requested Plain Enamel coating which is what I want correct?
PE Description - Plain Enamel, known as oleoresinous enamel, is still in use today in a variety of electronic components. Plain Enamel wires are manufactured to single-build dimensional standards.
Uses - Relays and coils
teravolt
Sun Aug 23 2009, 05:18AM
ebay is far cheeper I would think because ebay wire is surplus. How big is your coil
Sun Aug 23 2009, 01:47PM
Keep in mind the price of copper has skyrocketed in the past few years. Don't expect to get it for too "good" of a deal.
Austin
Sun Aug 23 2009, 06:06PM
teravolt wrote ...
My goal is for 10-12 foot arcs @ 7200kW input. But since this will be my first "from scratch" designed build I am still figuring out all the parameters. I am thinking about takings Steve Ward's secondary and primary design from his drsstc-2. And power it using the cm600's.
StevenCaton
Sun Aug 23 2009, 11:21PM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
I bought a fat roll of wire from Nebraska surplus sales once. Probably not the "best" place for price, but they have tons of other electrical products for sale as well. They have pretty good deals on some of the large value electrolytic caps.
Sun Aug 23 2009, 11:54PM
How about Parawire? All of their magnet wire is double built though, or so i was told. It seems that you have a choice though, so email them.
Plasma Lover
Mon Aug 24 2009, 12:45AM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
By far, you are better off going with surplus wire from eBay and trying to find it by the pound for less than eleven dollars a pound, including shipping. I've always done that, and it always works for me. Then again, I am sitting on some rather large spools of wire.
Austin
Mon Aug 24 2009, 02:12AM
Thanks guys!
I E-mailed one of the E-bay suppliers and he is fixing me up a custom length spool which is kinda cool.
