  • Guests: 41
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
can i use .47 caps instead of the .68 caps on steve's mini design?
Duality
Fri Aug 21 2009, 06:29PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
hello.
as the title says.
could i use a .47cap instead of the .68 on steve's design?
if not: why not?
and if yes: why?
got to ask cause it's directly on the wall plug,
and i don't wanna blow stuff up.
(ofcourse it's rectified) shades
schematic: http://www.stevehv.4hv.org/SSTC5/miniSSTCfnlsch.JPG
Fri Aug 21 2009, 06:37PM
Here's a bit of advice. If you ask a question such as this, at least post the schematic or a link to the schematic so people reading your post can reference it.
Nobody wants to *have* to look for the schematic themselves to answer *your* question.
And assuming you are referring to Steve's mini-SSTC, then the 0.47uF is fine.
Duality
Fri Aug 21 2009, 06:56PM
oops it totally forgot srry.
angry
i'll edit it right away.
just where are those caps for anny way?
Sat Aug 22 2009, 11:58AM
They form a return point for the half-bridge by voltage division. The voltage between the caps is near V/2, and the mosfets switch the primary between V and ground, which causes current to flow in opposite directions through the primary. The capacitance of the capacitors affects the impedance of the bridge, or how much current it will pass.
Duality
Sat Aug 22 2009, 01:56PM
always good to learn new stuff ^^
annyway by building this circuit.
(steve's mini sstc)
i am trying to learn more about tesla coils.
