  • Guests: 62
Long run sstc
Linas
Tue Aug 18 2009, 08:49AM Print
Hi
I have to make stable, long demo run SSTC (SSTC have to run, until secondary become hot).
To make that, i buy large heatsink (it can eradiate 100W heat without fan), so my fets will be just warm. Heatsink is large surface area madded from 1,2kg aluminum)
Also i decided to use diode blocking system (some high power schottky and 15ETX06 diode (18ns 15A).It will be full-bridge with IRFPS40N50L mosfets.
For driver, i think use PLL, will high power GDT driver (CT>PLL>UCC>ultrafast fets>GDT)
Secondary will be 0,1mm wire 8cm diameter 33cm tall
does any one have idea, how to make it more stable ? neutral
i
Tue Aug 18 2009, 10:19AM
If heating in the secondary is your major concern, add a fan at the bottom to cool up through the secondary tube, just remember large holes under the topload :)
Marko
Tue Aug 18 2009, 11:05AM
Overheating of the secondary, especially around the base, is the major issue. On my wireless power demonstration coil I used PVC tube for the secondary form and this limits the run time to few minutes at most.
A secondary that is intended to run for prolonged periods of time should definitely be wound on something more heat resistant (fiberglass, teflon, phenolic/bakelite), still combined with forced air cooling.
If that isn't enough, more extreme alternatives could be active oil cooling (using a plexiglas tube around the secondary and a motorcycle radiator) or making the secondary a skeleton-coil and blowing air through it.
Marko
Tue Aug 18 2009, 11:37AM
Just use forced air cooling. This will cool your secondary very effectively.
Linas
Tue Aug 18 2009, 12:03PM
maybe i will fill all secondary with epoxy glue, and that will help keep secondary just warm some time...
Tue Aug 18 2009, 02:11PM
Linas wrote ...
maybe i will fill all secondary by epoxy glue, and that will help keep secondary warm some time...
wait... what...
Tue Aug 18 2009, 05:30PM
MadsKaizer wrote ...
Linas wrote ...
wait... what...
Well, if you use thermally conductive materials, it will effectively increase surface area, like a heatsink. I have a stereo transformer that is potted with some very hard thermally conductive material, for heat dissipation. The highest voltage internally is 120v, so there is no need for electrical isolation. Though, i dont know anything about epoxy glue.
As Dr. Gigavolt said, forced air cooling would probably be sufficient. If not, i rather like the idea of the skeleton former. I have thought about using this before. And that with forced air cooling should make a cold coil. As long as you are not going for sparks longer than the secondary...
Tue Aug 18 2009, 06:36PM
Linas wrote ...
Just get a fan and blow it on the secondary directly.
You guys love to make things complicated.
teravolt
Wed Aug 19 2009, 03:50AM
better yet put a fan bellow the ciol and blow it up through the tube and outside
Wed Aug 19 2009, 12:03PM
Just a floor fan pointed at the windings is good enough (or a muffin fan)
There is very low thermal mass of the windings and the air will curve right around the secondary and cool it quite effectively. For best results, use minimal (or no) coating over the secondary)
