  • Guests: 54
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
ISOTOP diode
rp181
Sun Aug 16 2009, 07:54PM Print
I am looking for 3 dual diode ISOTOP package, fast to ultra-fast, above 20A. If they are single diode, I need 6.
PM me.
Sun Aug 16 2009, 11:28PM
If it is two diodes, do you want common cathode, comman anode, or series kind of arrangement?
Also, does it have to be ISOTOP? Or is TO-247 acceptable?
Edit: Also, do they have to be the same part number (in case they are all being used on seperate things and it does not matter) and what voltage?
rp181
Sun Aug 16 2009, 11:54PM
Two isolated diodes in one package. Same part numbers, and how did I forget voltage? 600v.
I guess TO-247 is fine, I perfer screw terminals though. It is for the diodes in a half bridge coilgun, so surge rating is important.
Wed Sept 09 2009, 01:18AM
I amp not too sure if they will work, but i have 6 60 amp continuous, 600 amps pulse, 120amp max repetitive ultrafast (50ns) TO-247. They are only 400v though, and single diode.
Let me know what you think.
rp181
Wed Sept 09 2009, 01:48AM
No thanks, A bit too small for comfort.
