  • Guests: 31
Anyone ever heard of this stuff ??
sparky99
Sat Aug 15 2009, 11:21PM Print
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
Was at a hamfest today & picked up a 2 gallon can of transformer oil. In a rectangular can with a red & yellow label that says "TRAFOOL" with a umlaut (the two dots that appear over a letter) over the last o. Nothing else on the label. Google search didn't help much. If you google "TRAFO" it comes back as German for "transformer". Oil in German is "OL".
The guy I bought it from said no PCB's & the can is in really excellent shape. Anyone ever seen, used or otherwise delt with this stuff? I don't want to waste a PCB test kit if I don't
need to.
Thanks,
Bob
IntraWinding
Sun Aug 16 2009, 12:18AM
I tried Googling "TRAFOÖL" (with the umlaut: Alt 153).
Lots of hits in German :
Results 1 - 10 of about 2,320 for "TRAFOÖL".
Good luck smile
J. Aaron Holmes
Sun Aug 16 2009, 12:25AM
"When it comes to insulating and cooling your transformer, don't be a fool; get ... TRA-FOOL!" cheesey
Cheers,
Aaron, N7OE
Renesis
Sun Aug 16 2009, 02:58AM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
Heh, öl is swedish for beer. That stuff must be for cheering up sad old pole pigs.
"Hi, im looking for a six-pack transformer oil"
Make shure you dont give it to much, it might... black out. Bwahaha shades
J. Aaron Holmes
Sun Aug 16 2009, 03:49AM
Renesis wrote ...
Too little, and it'll *cause* a blackout. There's a delicate balance to be struck here, no doubt (happily, indicated by a fill line).
smile
Seriously, though: Bob, if you've got a couple of those Dexsil 50ppm test kits, I say use one. What the heck, right? They're only ~$10, and that's hella-cheap for peace of mind, IMO. Else, if you've got a small quantity of some other tranny oil around, you might just compare the smell, color, and, with proper ventillation, flammability. I'm putting my money on non-PCB, however. PCBs were more common in caps and were disused just about everywhere by the mid 70's, so that'd have to be one unlucky, vintage can to be PCBs. And if you can't be bothered to test it, just don't cook with it, for God's sake! cheesey
Cheers,
Aaron, N7OE
