  • Guests: 70
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Drsstc doubler capacitors.
Sat Aug 15 2009, 01:48AM Print
This is the last part i need for the halfbridge for my drsstc. Maybe the last part for the whole thing.
I would like around 6000uf at 250vdc or so. More capacitance is alright, i don't mind, but 6000uf is enough, and the bigger they are the more startup current, and i do not plan a soft start to charge the caps upon turn on. The doubler diodes are 46 amps, and 300 amps pulse though, with a dissipation of about 300 watts each, on a heatsink, so that does not limit the cap size too much cheesey.
Low ESR is ideal, but as long as the ESR is not ridiculous, i can probably deal with it.
I have no money right now, so a trade might be the way to go. I can possibly trade an IGBT halfbridge brick, or something else. PM me if interested.
Thanks!
edit: If someone does indeed have good capacitors and there is a choice, i would prefer something 2.5 inches in diameter or so, but this seems a bit unrealistic. This is not a requirement.
