  • Guests: 59
Quarter Shinker
cduma
Thu Aug 13 2009, 07:15PM
cduma Registered Member #1822 Joined: Fri Nov 21 2008, 08:04PM
I cant do that. I already broke the bank buying the wire for this project($4.80).
cduma
Thu Aug 13 2009, 07:26PM
Post removed
Tesladownunder
Sat Aug 15 2009, 07:28PM
I have used a work coil wrapped in cloth and then wet and frozen in a block of ice. The ice acts as a solid if brittle mass but the cloth gives it integrity in a similar manner to steel reinforced concrete or fibreglass. It still gets smashed but it is easy to do and adds kg to the force holding things together.
The coil has forces of axial compression (will short circuit between turns) and radial expansion (will explode).
My can crushing site.
TDU
1250364196 10 FT74202 Coinshrink4fibreglasscoil Small
1250364196 10 FT74202 Coinshrinkicepost Small
1250364393 10 FT74202 Coinshrinkingyen5kjbox Small
1250364258 10 FT74202 Coinshrinkingyen5kjflipside Small
