  • Guests: 44
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Jasper - MMC finished
1 2 3 4
Dr. H.
Tue Aug 11 2009, 04:10PM Print
Good day guys
after more than one year of part gathering, it was time to start this coil. It will be CM600 driven, around 15 000uF on the bridge and around 720nF tank capacitors. It is being design in the building process soo no more details for now. Here some pics of the "part bin" tongue A lot of parts are missing from the pics though.
P.S. the tires are not part of the coil hee hee.
Special thanks goes to Dr. Spark, Dr. Hankenstein and my father.
Cheers :)
1250006994 931 FT0 Pic 6437
1250006994 931 FT0 Pic 6441
Tue Aug 11 2009, 06:29PM
Somehow, I can imagine where this is leading to....
You are up for an awesome journey, and I welcome you aboard!
Cheers, Finn Hammer
Tue Aug 11 2009, 08:47PM
Awsome!
Dr. H.
Wed Aug 12 2009, 01:21AM
Finn Hammer wrote ...
Hee hee - thanks smile
So - few pictures of on the progress (I've started before I posted the thread).
We need power ... lots of it ... soooo I've "paralleled" two 25A variacs. Been working on this thing more than 30 hours to make it look as I want it to smile EVERY part is modified/sanded/polished/painted ..... I've also changed the "slaves" with bearings - now the shaft moves much better and the awful wobbliness in the shaft is gone
The pictures shows everything.
I hope you like it. Cheers
1250040071 931 FT74132 Pic 6589
1250040071 931 FT74132 Pic 6597
1250040071 931 FT74132 Pic 6628
1250040071 931 FT74132 Pic 6630
1250040071 931 FT74132 Pic 6636
1250040071 931 FT74132 Pic 6617
Dr. H.
Thu Aug 13 2009, 10:26PM
I have built the chassis for the variac. Now I am waiting for the plexy to arrive .
Cheers smile
1250202371 931 FT74132 Pic 6643
1250202371 931 FT74132 Pic 6646
1250202371 931 FT74132 Pic 6639
Austin
Fri Aug 14 2009, 03:40AM
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
wow that is looking fantastic, guh I really wish I knew how to weld.
Dr. H.
Sat Aug 29 2009, 04:11PM
Good day guys
after more than a week of work on the project here is the progress on the variac :
all of the plexy parts are completed, holes for the air drilled and 90% of the stuff mounted on them. The most exciting part remains - taking of the protective cover from the plexy ... but I will do it at the end.
Also yesterday I've received the frame form the powder coating.
Tomorrow I begin final assembly.
Cheers smile
1251562291 931 FT74132 Pic 6690
1251562291 931 FT74132 Pic 6689
teravolt
Sat Aug 29 2009, 04:47PM
one slight comment, those gray ceramic caps are better suited for a VTTC if you plan to use them for your MMC cap. do you plan to get any poly snubber caps for your primary tank circuit
Dr. H.
Sat Aug 29 2009, 05:32PM
Good day sir
aaaa ... what gray ceramic caps ???
If you are speaking about the "gray parts", next to the diodes, in the beggining of the thread - those are 100A line filters, not capacitors.
Cheers smile
Dr Hankenstein
Sun Aug 30 2009, 12:39AM
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
Nice Meters
