  • Guests: 57
UV LED Triggered Spark gap
jpsmith123
Tue Aug 11 2009, 05:19AM Print
I wonder, can anyone get or has anyone seen the following paper? I'm very curious about this and I'd like to find out the details.
UV LED Triggered Spark Gap
Chung, M.
Plasma Science, 2007. ICOPS 2007. IEEE 34th International Conference on
Volume , Issue , 17-22 June 2007 Page(s):344 - 344
Digital Object Identifier 10.1109/PPPS.2007.4345650
Summary:Summary form only given. Spark gap is used extensively in all kinds of pulse generators, traditional Trigatron type spark gap relies on a pulsed high voltage (usually around 30 % of hold off voltage) to trigger the main gap breakdown. The statistical delay is inversely proportional to pressure and related to streamer propagation time. On the other hand, laser triggered spark gap require high cost YAG laser to provide very strong intensity (~109 W/cm2, tens of mJ energy) to ionize SF6 or air to initiate breakdown. UV flash lamp has also been used to trigger Thyratron in Back Light Thyratron (BLT). The emergence of high power (1-3 W) U V LED presents a new opportunity in triggering a spark gap. LED is compact, low cost, low voltage, and with very low jitter. One or several UV LEDs are positioned in the center of a Trigatron type spark gap to initiate the main discharge. Preliminary results of breakdown waveform and delay are discussed.
Tue Aug 11 2009, 05:54AM
pm sent
Tue Aug 11 2009, 08:50AM
Yes, I remember that paper attracted quite a bit of interest when it first came out, and I think I made a post about it here at the time.
So far as I recall, the UV LED used was of quite high power and shorter wavelength, than the little LEDs sold as "UV" which are really on the cusp of long wave UV and violet.
At the time, I remember looking at the data sheet of the UV LED, which coincidentally (!) appeared on the market at the same time as this paper, and noticing that it cost some hundreds of dollars.
This is from memory, so if it is very important to you, I should still advise you to verify it elsewhere.
But the point is this: you can smell ozone strongly around short UV sources, and nothing around the little near violet LEDs - what does that tell you?
You'd have much better results, in my view, with a DIY N2 laser (X = 337.1 nm) such as that constructed by 4HV member Plazmatron.
Sun Aug 16 2009, 09:19AM
hmm.. i've seen 370nm Nichia LED arrays on Ebay before, used for curing adhesives.
jpsmith123
Sun Aug 16 2009, 01:02PM
Unfortunately the "paper" doesn't provide much information, so the details are still lacking.
I don't know what wavelength was used in the study, but I suspect it would need to be shorter than 370 nm to ionize anything or to cause photoemission from the electrode surfaces.
As Harry said, it seems the shorter wavelength UV LEDs are very expensive...so I think this approach might not be practical right now, unfortunately.
Bored Chemist
Sun Aug 16 2009, 01:12PM
I can't see this working until they have LEDs that are short enough wavelength to be absorbed by air. That's about 190nm or so. roughly another octave to go.
How long did it take to get from red LEDs to blue ones?
Dr. Slack
Tue Aug 18 2009, 02:16PM
When those 370nm UV LEDs came out, I did some sums, and they will eject electrons from sodium electrodes. Unfortunately all more practical electrode materials need more punch per photon.
Sat Aug 22 2009, 11:56PM
hmm. there are now 270nm LEDs but are stupidly expensive.
IIRC a standard quartz window UV LED *might* be feasible to supercool and pulse at an amp or so, you might be lucky and run into a "Freak" which emits short wave pulses, like the early GaN blue did.
-A
