  • Guests: 42
SSTC polarity
Avi
Sun Aug 09 2009, 01:37PM Print
I have an SSTC setup in which the driver is a manually adjusted frequency oscillator which drives the GDT of a full bridge.
The full bridge is powered by an isolated transformer.
The question is, when i adjust everything such that it is functioning, why is it when I reverse the polarity of the primary coil or the GDT input does it barly work at all.
Note: re adjusting the frequency does not cause it to work.
Since there is no feedback, and it is fullwave squared AC, i can not come up with any simple explanation.
Sun Aug 09 2009, 02:21PM
It is caused by your primary and secondary circuit being 180 degrees out of phase, so very little power is transfered.
Avi
Sun Aug 09 2009, 03:49PM
MadsKaizer wrote ...
Avi wrote ...
No feedback, therefore phase is irrelevant.
Sun Aug 09 2009, 05:57PM
Sounds peculiar to me,
what happens when you reverse BOTH the GDT and the primary phase?
Sun Aug 09 2009, 06:14PM
Doesn't make sense.
Sounds to me like you may be inadvertently affecting something else or not making a proper connection when you are switching polarity.
LithiumLord
Mon Aug 10 2009, 11:20AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Just a guess - your control electronics are unshielded, right? If they are, you already know what to do ;)
Avi
Fri Aug 14 2009, 12:12PM
Sulaiman wrote ...
then it works again
i also don't get a sharp resonant response in the not working polarity if that signifies anything?
LithiumLord wrote ...
hm, but it can be unshielded if i connect it a particular polarity?
