  • Guests: 80
Question about Dual Mot Power
Alexandre
Thu Aug 06 2009, 01:56PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
I saw some videos on YT of coils that worked with a DUAL MOT, and I was half puzzled,
when I saw that used a RSG in the place of the traditional Static gap, as I used in one of my versions ...
Well, I tried to put in my dual mot RSG and to my surprise did not work, the RSG not fired ...
an example of video:
In the first half of video coil run at 2 mot, and In the second half 2 mot with the voltage doubler
Now the question:
When using a RSG in a coil with two mot, it is necessary that the contacts are very close to work? which may be the problem?
thanks to all
