  • Guests: 51
Flyback Questions
SilentCoronas
Thu Aug 06 2009, 10:34AM Print
SilentCoronas Registered Member #2171 Joined: Thu Jun 11 2009, 10:15AM
I made this PCB from UZZORS2K' Schematics, but it seems to be runnig very hot on the four transistors. The PCB version is drawing as much as 1A.. breadbord only 0.09 at all times? This is my 2nd layout attempt. Would anyone be so kind as to check it out for me, as i am unable to see what i did wrong here.. heres a flick of PWM running off breadboard and hardwired powerstage : http://www.youtube.com/watch?v=E-dpI6KSGBQ
Hope you'll help me out smile
1249554659 2171 FT0 Schempcb
Thu Aug 06 2009, 02:05PM
I did not find any errors in your PCB, are you using the same GDT as you used on the breadboard?
SilentCoronas
Thu Aug 06 2009, 02:45PM
MadsKaizer wrote ...
Hi Mads, thx for posting!
Yes I used the same GDT. Made a powerstage PCB too, seems the breadboard PWM runs high driving that, so I thought it was that at first, but my PCB'ed PWM runs hot on the Hardwired powerstage aswell, not as badly though, also seems to draw more current at lower frequencies. I have interchanged all my available setups, and I think my Halfbridge PCB has a problem since both breadboard PWM and PCB'ed one runs hot on it, just cant seem to figure out where i messed up! Here is the halfbridge:
1249569884 2171 FT73852 Schempcb2
Thu Aug 06 2009, 06:00PM
I can't see anything wrong with the half-bridge PCB either. Maybe use larger spacing between the traces, as there is significant differences in potential between them. Have you tried a quick lash-up bridge to see if it causes heating too?
SilentCoronas
Thu Aug 06 2009, 06:32PM
Hi uzzors!
yup, tried feeding my lashed up bridge, the one i used in the tube-vid, lower heating, but draws around 220mA (breadboard 90-110mA) full duty cycle, also when I lower the frequency, it's still pulling 1A or so.. Will space out the paths some, knew it was probably a bit tight with just .5 mm. Set up my breadboard driver with my pcb bridge, and it instantly pulled over 1A. Checked all components are in their right places, and caps polarized right too.. Parts are from farnell, checked values and they are all good. Apart from heating up, the PCB's perform fairly, as long as i avoid running at lower frequencies. Being the noob, I hope I make sense:-p
Fri Aug 07 2009, 04:07PM
Do the transistors heat with no GDT present? The frequency dependency sounds like a GDT problem, ie saturation. I just noticed you've used a very old schematic, I've since started using some "fixes":
1) DC blocking capacitor.
2) A single damping resistor on the primary side of the GDT, and none on the secondary.
See my newer schematics if you don't know where to put these. The DC blocking capacitor will prevent saturation by any unevenness in the waveform, while the primary damping resistor won't explode if the bridge does, and is 1/2 the price of using two.
SilentCoronas
Fri Aug 07 2009, 05:45PM
Thx for the advice, I'll try it out and see what happens.
The transistors doesn't heat much either with or without the GDT, so I think now my problem is in the bridge. when i drive the lashed-up bridge from the PCB driver, only moderate heating occurs. My breadboarded driver hates the bridge PCB. I am tempted to dump this project, and move onto your newer stuff, but I'd sure like to know what went wrong, and learn from it.
Now armed with newer schematics, and some fresh parts in the mail, i am set for a weekend of experimenting and reading.. what is puzzling me, is that the breadboard and lashed-up setup is working great, and the PCB's should be ok, and with excact same components in them, yet they act up. also did scope out my GDT's and the new commercial pulse transformers i got, and they seem to tolerate the frequencies quite well, pretty nice square waves, and my own toroid being the better of the two. did xperiment a while and ended up with 30 trifilar windings on a EPCOS - B64290L618X38 - FERRITE RING CORE, 25.3X14.8X10 http://www.farnell.com/datasheets/80884.pdf - Anyhow i will see if i can get your newer setup put together, and see where that takes me. need to gulp down a fair bit of theory aswell!
ordered some MCP1407-E/P driver IC's, to try and get rid of them lil 139/140's aswell... think they should do ok?
Cheers, Sean
Fri Aug 07 2009, 06:12PM
30 turns on that type of core should handle relatively low frequencies. I always use B64290L618X'830' cores for my GDTs which have lower µi, so yours will preform even better. Replacing the BD1XX'es with gate driver chips is a good idea.
