  • Guests: 45
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
non working tesla coil
Domoljub2
Tue Aug 04 2009, 03:34PM Print
Domoljub2 Registered Member #2267 Joined: Tue Aug 04 2009, 01:24PM
Hi.
I have build my first tesla coil and guess what, it doesn't work.
Transformer is 230/5500 V (current limited).
I had secondary N=2090 turns 0.1mm. But it didn't work. Than I made a new one 1111 turns, 0.25mm.
A friend gave me some old capacitor, that was laying around, as you can see in the picture 25nF, 15000 VDC.
For the grounding of the secondary, I used water pipe.
I used static spark gap.
When I turn it on, I only get sparks in the spark gap. I get no streamers on the secondary. Nothing at all.
I was changing turns of the primary no success.
Does anybody have any idea? I attached some pictures.
PS: I am sorry for my bad english.
1249400055 2267 FT0 040820093034
1249400055 2267 FT0 080720092317
1249400055 2267 FT0 220720092428
1249400055 2267 FT0 230720092446
Myke
Tue Aug 04 2009, 05:36PM
Did you tune the primary's resonant freq to match the secondary's resonant freq? maybe try to increase the coupling between your primary and your secondary?
Jonathan Dennis
Tue Aug 04 2009, 07:07PM
Jonathan Dennis Registered Member #2153 Joined: Wed Jun 03 2009, 03:19PM
which coil are you trying to get to work? The one in the first or the last picture?
Domoljub2
Tue Aug 04 2009, 07:42PM
I made the smaller one first(last picture) and it didn't work, then I made a new one(first picture).
The resonant freq should match. I was also changing turns of the primary circuit. Tomorrow I will experiment forward. I would be happy if I would get sparks 1 cm long.
In theory it should work :D
Jonathan Dennis
Tue Aug 04 2009, 10:18PM
are you using any software to check your design? Try WinTesla or TeslaMap. If you don't have much experience tesla map will probably be easier to use and make a little more sense. I would highly recommend checking your design with one of these programs though.
Hazmatt_(The Underdog)
Wed Aug 05 2009, 10:55AM
It's going to be difficult to get this coil going because you are most likely way out of tune, and are using low power, eg. 15mA or so at 5500V.
I'd say for initial testing, tap midway on your primary and take your foil off the top so you can see if you get any output from the top lead. If not, then move a turn out or turn in, and keep moving around until you see improvement. You won't see much of anything with this setup, but you will get what you get.
Spark gap: maybe 1/8" open max. Just make sure its buzzing. Low voltage is kinda a pain to deal with. One of my early coils was a 7500V system and I had some trouble with the gap here.
This coil probably isn't going to do much with that top load. I'd say after you can see some sparks and get a feel for what it does, make a little 12" diameter toroid for it.
You're not really going to get streamers from something this small. You need to put a breakout point on the discharge surface and actually get your ground electrode in proximity to see a discharge.
If you had a lot more power then you could expect some streamers out.
oucivileng
Thu Aug 06 2009, 04:08AM
oucivileng Registered Member #1772 Joined: Tue Oct 21 2008, 05:23AM
i'm gonna bet that your capacitor is shot. it's a lot quieter if you disconnect the capacitor right? a second-hand capacitor sounds kind of risky
