  • Guests: 45
Grounding question.
Tigeris
Tue Aug 04 2009, 05:50AM Print
Tigeris Registered Member #1656 Joined: Wed Aug 27 2008, 03:28PM
Ok. i have read lots of things here about grounding a secondary coil. Some say use a metal rod out side, some say its ok to ground on the third prong on the mains. I have a fairly small one. 7.5 Kv 30ma. 20 kv. door knob cap. Approx. 730 turns on the primary, 8 turns on the primary.
I just want to know, is it safe to ground it to the mains? or should i use a rod? If i ground it to the mains, should i use a filter of some kind?
thanks for the help.
Tue Aug 04 2009, 11:30AM
Tigeris wrote ...
Grounding directly to the MAINS always presents a risk to other equipment in your house which could be damaged regardless of the power levels.
Although I don't recommend it (always using a dedicated ground is good practice), i have used MAINS ground for coils using similar "low power" transformers. However, if you do, you do at your own risk. Just disconnect any sensitive equipment from the line (computers, stereos, TV's, etc...)
Tigeris
Thu Aug 06 2009, 04:21PM
Dr. GigaVolt wrote ...
Tigeris wrote ...
Thanks. its nice to get a good answer. I have lots of very touchy equipment in my house, and want to keep them working :P
