  • Guests: 61
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
can someone please help me with some parts (ferrite core, filament transformer)
audio:deviant
Mon Jul 27 2009, 10:09PM Print
audio:deviant Registered Member #2081 Joined: Wed Apr 15 2009, 11:36AM
hello all,
i've searched high and low, maybe its cos im not looking for the right thing, i really dont know...
anyways im based in the UK so looking for local suppliers and 240 volts and im using the mini brute design, im trying to track down a filament transformer 24VAC, 48VA. and a ferrite core for the half bridge. little bit stuck at the moment and i really want to get this project done as im on a bit of a deadline.
thanks a lot gang! some sort of pointing me in the right direction would be great!
cduma
Mon Jul 27 2009, 10:45PM
What do you mean by "ferrite core for the half bridge"? All you need for a half bridge is a single diode. You dont even need DC for a filament any ways.
audio:deviant
Mon Jul 27 2009, 10:59PM
theres a pic of one, the bit wrapped up in wire...
cduma
Tue Jul 28 2009, 01:41AM
Hmmm...
Quite clearly this is something other than what I thought. A good place to find the ferrite core is inside the power supply of a PC or inside any power brick/wall wart with primary resistance that is not indicative of a transformer which means switch mode power supply which usually use that type of transformer. If you use ones from a PC be careful since there are two large filter capacitors which will do more than tickle.
Tue Jul 28 2009, 02:21AM
There is usually no difficulty finding common parts like 24V transformers on ebay. Here are a few that took only a minute or two to find using the search term "transformer 24V", which you might like to try doing yourself now:
Both of these look a little expensive to me, but if you hold out for a bit I would expect to get a 24V transformer of a few amps rating for less than £10 bye and bye.
Tue Jul 28 2009, 10:03AM
RS or Farnell have everything you need.
Tue Jul 28 2009, 10:32AM
I second Steve on Farnell, with whom I deal regularly. Thier online catlogue is excellent, they are very reliable, and parts come the next day as a matter of course.
Nicko
Tue Jul 28 2009, 12:19PM
I use Farnell, RS & Rapid Electronics every week - Both Farnell & RS do next-day delivery as part of the deal, and quality & range of stock is excellent. They are not the cheapest, but you get what you pay for. Farnell now stock (actually have in stock) nearly 500,000 lines... 95+% of what I use (which is a fairly eclectic mix of stuff) comes from the above suppliers in the UK.
Note you can also use DigiKey from the UK (they have a UK site) with a minimum order charge & shipping, but you can order any of their parts for very rapid delivery to UK mainland.
I've built a minibrute - most of my bits came from Farnell - note, and I hope you realise this, that the miniBrute is a 120VAC design, and needs some modification for 240V for the HV rails for the bridge (lose the voltage doubler etc).
HTH
audio:deviant
Tue Jul 28 2009, 09:19PM
cheers for the replies gang, the farnell company is pretty good! they actually have everything. just this ferrite core i have no idea about them says its a type 78??
nicko i thought i still needed a 24vac transformer or is that the doubler?
Tue Jul 28 2009, 09:35PM
Yeah, that would be Fair-Rite type 78 I guess. RS have toroids in that ferrite grade, such as part no. 467-4454, but Farnell don't seem to stock them. They probably have an equivalent part from Epcos or whoever, though.
