  • Guests: 43
Primary winding question
eniyuki
Mon Jul 13 2009, 03:58PM Print
eniyuki Registered Member #2148 Joined: Tue Jun 02 2009, 02:22AM
hi its me again eni
please ignore the first 3 posts because i just edited my old thread.
first this is my primary winding that i wound lately
14072009654
14072009657
14072009661
14072009662
14072009658
but i have problems and questions
it has dents because of the "snap on"
i PINCHED the first end of the tube for some reasons. IS THAT OKAY?
any suggestion, how will i connect the WIRES to the copper tube? THANK YOU!
Mon Jul 13 2009, 05:09PM
What type of coil are you building? Unless you are using feedback (like in a sstc/vttc) the direction does not matter.
Plasma Lover
Mon Jul 13 2009, 05:19PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
The forum has a search function for a reason.
It doesn't matter, as long as all of the winding is going in the same direction, including your tuning wire.
Whoops, I guess I left that tab open too long.
Mon Jul 13 2009, 06:49PM
A TC will work with the secondary wound in the same OR opposite direction to the primary.
I haven't proved it yet but I'm of the opinion that
arcs are less likely to strike the primary or strike rail
if primary and secondary are wound in the same direction.
If this is true it's a small effect and something that you should NOT worry about.
All my primaries are helical which when turned upside-down there is no change,
I need to wind a flat primary that will reverse winding directiopn when inverted.
One more thing on a very long list ;)
eniyuki
Wed Jul 15 2009, 04:17PM
thanks thanks!
eniyuki
Thu Jul 16 2009, 04:10AM
anyone?
Thu Jul 16 2009, 04:34AM
The dents and the crimped end will not affect operation noticeably.
