  • Guests: 152
Online PCB Fabrication
Killa-X
Mon Jul 13 2009, 03:16AM
I always wanted to know the priced of boards but, Now I know why I rather attempt my own...I mean people have their own ways but with the right technique, double sided homebrew boards are easy. But, Some people don't have the time to do it. As long as I can get my clads for 50 cents like I've been, for 4X8". It will serve me very good :)
Curtis
Mon Jul 13 2009, 04:14PM
Curtis Registered Member #883 Joined: Sat Jul 07 2007, 01:02PM
If this is going to be a long term hobby, Probotix sells their fireball CNC router for under a grand. In 15 PCB runs it pays for itself. Software is free as long as you don't make any money off of it. I'm saving for mine right now.
magnetomotive
Wed Jul 15 2009, 12:51AM
magnetomotive Registered Member #267 Joined: Mon Feb 27 2006, 09:44PM
Curtis wrote ...
Man, I sure would like to have one of those CNC machines, but I'll probably consider getting one of those if I decide to keep building coils after my first DRSSTC.
Nicko
Wed Jul 15 2009, 05:32AM
I use Olimex a lot for PCB fabrication - cheap, pretty good and they take Eagle files directly.
See my current uDR/SSTC thread for some new boards I had made this week...
HTH
Jrz126
Thu Jul 16 2009, 01:18PM
Jrz126 Registered Member #242 Joined: Thu Feb 23 2006, 11:37PM
I found this place: Link2
$0.45 /sq inch.
I dont know how good they are, but it is definitly cheap. I'm using them to get some boards made for work. I'll let you guys know once I get them.
teravolt
Thu Jul 16 2009, 07:20PM
thanks Jrz126 that is a exalent site and i will try it. they are cheap and they accept multiple formats
magnetomotive
Thu Jul 16 2009, 07:44PM
Jrz126 wrote ...
$0.45 /sq inch.
That looks like the best site so far. Hopefully the quality is good.
Nicko
Fri Jul 17 2009, 05:36AM
Jrz126 wrote ...
Olimex panelize for free - for a double-sided, soldermasked & silkscreened eurocard (160mm x 100mm) driven from Eagle, Futurlec charge $77 + P&P. Olimex charge euros 30 (USD 42.35)/panel + P&P - Olimex have no setup charges, Futurlec charge 25 bucks. Futurlec don't panelise - Olimex do it for free (put several smaller boards onto one eurocard then cut it up into individual boards again as part of the service.
Olimex go down to 8 mil resolution at same cost - Futurlec's minimum resolution is 10 mil (not a problem except for some SMD boards).
Olimex are certainly significantly cheaper for what I do at least, and the free panelisation is a feature I use pretty much every order - quality pretty good too, as is delivery time (typically 5 working days).
